I’m using the torizoncore-builder to download an already defined lockbox from the Torizon cloud.
When I call on the command line
source tcb-env-setup.sh -a remote
torizoncore-builder -h
this works fine.
Now I want to do this in a bash script:
#!/bin/bash
shopt -s expand_aliases
This also works well.
But when I change the script to the following
#!/bin/bash
bash -c "shopt -s expand_aliases; source tcb-env-setup.sh -a remote; torizoncore-builder -h"
I get the error that the command torizoncore-builder cannot be found.
Why is that?
Markus
Hello Markus,
Great question! This is a common issue related to how shell aliases work in Bash, especially when dealing with subshells and scripts.
Why does it happen?
The TorizonCore Builder setup script sets up torizoncore-builder as a Bash alias (see docs)(more here). By default, Bash aliases are not inherited in non-interactive subshells and are available only in the shell session where the alias was defined and aliases are enabled.
In your last example:
you’re creating a new non-interactive shell. Even though you’re enabling alias expansion with shopt, the alias defined in tcb-env-setup.sh is valid only for that subshell. It will not persist or be exported to further child processes, and in non-interactive shells, some distributions or configurations may still not honor aliases fully.
Recommended solutions
Use the same shell session:
Either source the setup script and use the alias directly in your current shell (as in your working examples).
Directly use the Docker run command:
If you look in the tcb-env-setup.sh file, the torizoncore-builder alias typically points to a Docker run command. You could use this command directly in scripts for more predictability.
Stick with sourcing in the script:
As you’ve shown, the approach that works best in automation is to source the script in your Bash script, not in a subshell.
Summary
- The alias only exists in the shell where it was defined and won’t be transferred to a
bash -c context.
- Sourcing in your script (
source tcb-env-setup.sh -a remote) is the way to go for automation.
References:
ChatGPT o3 gave me a better answer
Why does the third case with bash -c "…" fail?
Alias expansion happens when the shell reads/parses the command, not when it executes it. In non-interactive shells (like bash -c), aliases are only expanded if expand_aliases is set — but only for aliases that already exist at parse time. If the alias is created by source …, then the following command in the same -c string has already been parsed, so no expansion occurs → “command not found”.
Solution:
re-parse after sourcing with eval:
bash -c 'shopt -s expand_aliases; source tcb-env-setup.sh -a remote; eval "torizoncore-builder -h"'
Markus
