Based on the available documentation, Torizon Cloud uses Uptane as the underlying framework for secure software updates, including offline updates via lockboxes(1). The Uptane metadata for a lockbox is signed with a key specific to the offline updates role(2).
According to the API documentation, the signing method used is rsassa-pss-sha256(2). This indicates RSA signing with PSS (Probabilistic Signature Scheme) padding and SHA-256 hashing.
However, the specific key size (e.g., 2048-bit, 4096-bit RSA) is not explicitly documented in the available sources. For your cybersecurity architecture documentation, I recommend:
- Checking the Uptane metadata directly via the API endpoint
GET /lockboxes/{lockbox_name}(2) to examine thekeyidand signature details - Reviewing the Uptane standard specifications, as Torizon Remote Updates is built on Uptane(1)
- Contacting Toradex support for official confirmation of the exact key size used in production
The signing ensures authenticity and integrity of the lockbox packages, with the public key distributed to devices for verification(3).
