Lockbox Algorithm and Key Size
We’re using Torizon Cloud to generate offline updates and want to document some information for our cybersecurity architecture. What is the algorithm and key size used to sign the update/lockbox?
Based on the available documentation, Torizon Cloud uses Uptane as the underlying framework for secure software updates, including offline updates via lockboxes(1). The Uptane metadata for a lockbox is signed with a key specific to the offline updates role(2).
According to the API documentation, the signing method used is rsassa-pss-sha256(2). This indicates RSA signing with PSS (Probabilistic Signature Scheme) padding and SHA-256 hashing.
However, the specific key size (e.g., 2048-bit, 4096-bit RSA) is not explicitly documented in the available sources. For your cybersecurity architecture documentation, I recommend:
  1. Checking the Uptane metadata directly via the API endpoint GET /lockboxes/{lockbox_name}(2) to examine the keyid and signature details
  2. Reviewing the Uptane standard specifications, as Torizon Remote Updates is built on Uptane(1)
  3. Contacting Toradex support for official confirmation of the exact key size used in production
The signing ensures authenticity and integrity of the lockbox packages, with the public key distributed to devices for verification(3).
Greetings @suntra-chrisg,
By default for signing updates in general on Torizon Cloud we use RSA4096, at least at the time of writing.
It should be noted that it is an option to take full ownership of the signing keys used for your updates rather than relying on Toradex to manage the keys, as is the default. This procedure is documented here: Offline Signing Keys | Toradex Developer Center
