Environment:
Verdin iMX8M Plus
TorizonCore 5.3.0-devel-202106+build.14
Issue:
Unable to deploy and debug using Windows 10 and Verdin iMX8M Plus board. I’m see the following error when the image is being deployed:
Here’s is a copy of the trace in the Terminal tab:
INFO:root:REST -> /api/platforms/arm64v8-qt5-vivante-no-ssh_bullseye/compatibledevices
DEBUG:connexion.apis.flask_api:Getting data and status code
DEBUG:connexion.decorators.validation:http://localhost:5001/api/platforms/arm64v8-qt5-vivante-no-ssh_bullseye/compatibledevices validating parameters...
DEBUG:connexion.decorators.parameter:Function Arguments: ['platform_id']
DEBUG:connexion.apis.abstract:Getting data and status code
DEBUG:connexion.apis.abstract:Prepared body and status code (200)
DEBUG:connexion.apis.abstract:Got framework response
INFO:root:REST <- /api/platforms/arm64v8-qt5-vivante-no-ssh_bullseye/compatibledevices - 200
INFO:root:REST -> /api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/updated
DEBUG:connexion.decorators.validation:http://localhost:5001/api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/updated?configuration=debug validating parameters...
DEBUG:connexion.decorators.parameter:Function Arguments: ['application_id', 'configuration']
DEBUG:connexion.operations.abstract:Query Parameter 'configuration' in function arguments
DEBUG:connexion.operations.abstract:configuration is a {'x-scope': [''], 'name': 'configuration', 'in': 'query', 'type': 'string', 'required': True, 'pattern': '(?:debug|release)'}
DEBUG:docker.utils.config:Trying paths: ['/home/torizon/.docker/config.json', '/home/torizon/.dockercfg']
DEBUG:docker.utils.config:No config file found
DEBUG:urllib3.connectionpool:http://localhost:None "GET /version HTTP/1.1" 200 861
DEBUG:urllib3.connectionpool:http://localhost:None "GET /v1.41/images/sha256:2b5071999eb6b953f24c736781644e0717bf0d5435dc08b2022c5d47c760c8be/json HTTP/1.1" 200 None
INFO:root:Image is up to date.
INFO:root:REST <- /api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/updated - 200
INFO:root:REST -> /api/progress/create
DEBUG:connexion.decorators.parameter:Function Arguments: []
INFO:root:REST <- /api/progress/create - 200
INFO:root:REST -> /api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/deploy
DEBUG:connexion.decorators.validation:http://localhost:5001/api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/deploy?configuration=debug&device_id=07011707&progress_id=6ba2115a-6d01-42f9-ac57-81d25cf5b068 validating parameters...
DEBUG:connexion.decorators.parameter:Function Arguments: ['application_id', 'configuration', 'device_id', 'progress_id']
DEBUG:connexion.operations.abstract:Query Parameter 'device_id' in function arguments
DEBUG:connexion.operations.abstract:device_id is a {'x-scope': [''], 'name': 'device_id', 'description': 'Target device serial number', 'in': 'query', 'type': 'string', 'required': True, 'pattern': '^[-0-9a-zA-Z.]*$'}
DEBUG:connexion.operations.abstract:Query Parameter 'progress_id' in function arguments
DEBUG:connexion.operations.abstract:progress_id is a {'x-scope': [''], 'name': 'progress_id', 'description': 'Id of a progress cookie (uuid)', 'in': 'query', 'type': 'string', 'required': False, 'pattern': '^$|[0-9,a-f,A-F]{8}-[0-9,a-f,A-F]{4}-[0-9,a-f,A-F]{4}-[0-9,a-f,A-F]{4}-[0-9,a-f,A-F]{12}$'}
DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): 127.0.0.1:43725
DEBUG:paramiko.transport:[chan 2] Max packet in: 32768 bytes
DEBUG:paramiko.transport:[chan 2] Max packet out: 32768 bytes
DEBUG:paramiko.transport:Secsh channel 2 opened.
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "GET /version HTTP/1.1" 200 970
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "GET /v1.40/images/myapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c:latest/json HTTP/1.1" 404 233
INFO:root:DEPLOY - Image not found on target device.
INFO:root:Image not found on target device.
INFO:root:Setting up proxy on client.
DEBUG:urllib3.connectionpool:http://localhost:None "GET /v1.41/containers/docker-desktop_TIE_docker_registry/json HTTP/1.1" 404 68
DEBUG:urllib3.connectionpool:http://localhost:None "GET /v1.41/volumes/docker-desktop_TIE_docker_registry HTTP/1.1" 200 223
DEBUG:urllib3.connectionpool:http://localhost:None "POST /v1.41/containers/create?name=docker-desktop_TIE_docker_registry HTTP/1.1" 201 88
DEBUG:urllib3.connectionpool:http://localhost:None "GET /v1.41/containers/ccf8924071c75b7792abfd57ac56efa5adccf9658964f21189bceac2a78aa292/json HTTP/1.1" 200 None
INFO:root:REST -> /api/progress/status
DEBUG:connexion.decorators.validation:http://localhost:5001/api/progress/status?progress_id=6ba2115a-6d01-42f9-ac57-81d25cf5b068 validating parameters...
DEBUG:connexion.decorators.parameter:Function Arguments: ['progress_id']
INFO:root:REST <- /api/progress/status - 200
DEBUG:urllib3.connectionpool:http://localhost:None "POST /v1.41/containers/ccf8924071c75b7792abfd57ac56efa5adccf9658964f21189bceac2a78aa292/start HTTP/1.1" 204 0
DEBUG:urllib3.connectionpool:http://localhost:None "GET /v1.41/containers/docker-desktop_TIE_docker_registry/json HTTP/1.1" 200 None
INFO:root:Local docker registry docker-desktop_TIE_docker_registry running on localhost:49156.
DEBUG:paramiko.transport:[chan 3] Max packet in: 32768 bytes
DEBUG:paramiko.transport:[chan 3] Max packet out: 32768 bytes
DEBUG:paramiko.transport:Secsh channel 3 opened.
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "GET /v1.40/containers/docker-desktop_TIE_docker_registry/json HTTP/1.1" 200 None
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "POST /v1.40/containers/593b7b5c1a816a94c9d728a0e5e92e72b9db60cd32b0c7818a04c5fcc0a17d62/stop HTTP/1.1" 204 0
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "DELETE /v1.40/containers/593b7b5c1a816a94c9d728a0e5e92e72b9db60cd32b0c7818a04c5fcc0a17d62?v=False&link=False&force=True HTTP/1.1" 404 98
INFO:root:SSH - Connecting to device 07011707
DEBUG:paramiko.transport:starting thread (client mode): 0x185ffca0
DEBUG:paramiko.transport:Local version/idstring: SSH-2.0-paramiko_2.11.0
DEBUG:paramiko.transport:Remote version/idstring: SSH-2.0-OpenSSH_8.2
INFO:paramiko.transport:Connected (version 2.0, client OpenSSH_8.2)
DEBUG:paramiko.transport:=== Key exchange possibilities ===
DEBUG:paramiko.transport:kex algos: curve25519-sha256, curve25519-sha256@libssh.org, ecdh-sha2-nistp256, ecdh-sha2-nistp384, ecdh-sha2-nistp521, diffie-hellman-group-exchange-sha256, diffie-hellman-group16-sha512, diffie-hellman-group18-sha512, diffie-hellman-group14-sha256
DEBUG:paramiko.transport:server key: rsa-sha2-512, rsa-sha2-256, ssh-rsa, ecdsa-sha2-nistp256, ssh-ed25519
DEBUG:paramiko.transport:client encrypt: chacha20-poly1305@openssh.com, aes128-ctr, aes192-ctr, aes256-ctr, aes128-gcm@openssh.com, aes256-gcm@openssh.com
DEBUG:paramiko.transport:server encrypt: chacha20-poly1305@openssh.com, aes128-ctr, aes192-ctr, aes256-ctr, aes128-gcm@openssh.com, aes256-gcm@openssh.com
DEBUG:paramiko.transport:client mac: umac-64-etm@openssh.com, umac-128-etm@openssh.com, hmac-sha2-256-etm@openssh.com, hmac-sha2-512-etm@openssh.com, hmac-sha1-etm@openssh.com, umac-64@openssh.com, umac-128@openssh.com, hmac-sha2-256, hmac-sha2-512, hmac-sha1
DEBUG:paramiko.transport:server mac: umac-64-etm@openssh.com, umac-128-etm@openssh.com, hmac-sha2-256-etm@openssh.com, hmac-sha2-512-etm@openssh.com, hmac-sha1-etm@openssh.com, umac-64@openssh.com, umac-128@openssh.com, hmac-sha2-256, hmac-sha2-512, hmac-sha1
DEBUG:paramiko.transport:client compress: none
DEBUG:paramiko.transport:server compress: none
DEBUG:paramiko.transport:client lang: <none>
DEBUG:paramiko.transport:server lang: <none>
DEBUG:paramiko.transport:kex follows: False
DEBUG:paramiko.transport:=== Key exchange agreements ===
DEBUG:paramiko.transport:Kex: curve25519-sha256@libssh.org
DEBUG:paramiko.transport:HostKey: ssh-ed25519
DEBUG:paramiko.transport:Cipher: aes128-ctr
DEBUG:paramiko.transport:MAC: hmac-sha2-256
DEBUG:paramiko.transport:Compression: none
DEBUG:paramiko.transport:=== End of kex handshake ===
DEBUG:paramiko.transport:kex engine KexCurve25519 specified hash_algo <built-in function openssl_sha256>
DEBUG:paramiko.transport:Switch to new keys ...
DEBUG:paramiko.transport:Got EXT_INFO: {'server-sig-algs': b'ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com'}
DEBUG:paramiko.transport:Trying SSH key b'447d1711e29cbce5b3778320e040abbf'
DEBUG:paramiko.transport:userauth is OK
DEBUG:paramiko.transport:Finalizing pubkey algorithm for key of type 'ssh-rsa'
DEBUG:paramiko.transport:Our pubkey algorithm list: ['rsa-sha2-512', 'rsa-sha2-256', 'ssh-rsa']
DEBUG:paramiko.transport:Server-side algorithm list: ['ssh-ed25519', 'sk-ssh-ed25519@openssh.com', 'ssh-rsa', 'rsa-sha2-256', 'rsa-sha2-512', 'ssh-dss', 'ecdsa-sha2-nistp256', 'ecdsa-sha2-nistp384', 'ecdsa-sha2-nistp521', 'sk-ecdsa-sha2-nistp256@openssh.com']
DEBUG:paramiko.transport:Agreed upon 'rsa-sha2-512' pubkey algorithm
INFO:paramiko.transport:Authentication (publickey) successful!
INFO:root:SSH - Connected to device 07011707
DEBUG:paramiko.transport:[chan 0] Max packet in: 32768 bytes
DEBUG:paramiko.transport:Received global request "hostkeys-00@openssh.com"
DEBUG:paramiko.transport:Rejecting "hostkeys-00@openssh.com" global request from server.
DEBUG:paramiko.transport:Debug msg: b'/home/torizon/.ssh/authorized_keys:2: key options: agent-forwarding port-forwarding pty user-rc x11-forwarding'
DEBUG:paramiko.transport:[chan 0] Max packet out: 32768 bytes
DEBUG:paramiko.transport:Secsh channel 0 opened.
DEBUG:paramiko.transport:[chan 0] Sesch channel 0 request ok
DEBUG:paramiko.transport:[chan 0] EOF sent (0)
DEBUG:paramiko.transport:[chan 0] EOF received (0)
DEBUG:paramiko.transport:[chan 1] Max packet in: 32768 bytes
DEBUG:paramiko.transport:[chan 1] Max packet out: 32768 bytes
DEBUG:paramiko.transport:Secsh channel 1 opened.
DEBUG:paramiko.transport:[chan 1] Sesch channel 1 request ok
DEBUG:paramiko.transport:[chan 1] EOF sent (1)
DEBUG:paramiko.transport:[chan 1] EOF received (1)
DEBUG:paramiko.transport:[chan 2] Sesch channel 2 request ok
DEBUG:paramiko.transport:[chan 2] EOF sent (2)
DEBUG:paramiko.transport:[chan 2] EOF received (2)
DEBUG:paramiko.transport:[chan 3] Sesch channel 3 request ok
INFO:paramiko.transport.sftp:[chan 3] Opened sftp connection (server version 3)
DEBUG:paramiko.transport.sftp:[chan 3] open(b'/home/torizon/certs/docker-desktop.tie.cert', 'wb')
DEBUG:paramiko.transport.sftp:[chan 3] open(b'/home/torizon/certs/docker-desktop.tie.cert', 'wb') -> 00000000
DEBUG:paramiko.transport.sftp:[chan 3] close(00000000)
DEBUG:paramiko.transport.sftp:[chan 3] stat(b'/home/torizon/certs/docker-desktop.tie.cert')
INFO:paramiko.transport.sftp:[chan 3] sftp session closed.
DEBUG:paramiko.transport:[chan 3] EOF sent (3)
DEBUG:paramiko.transport:[chan 3] EOF received (3)
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "POST /v1.40/containers/create?name=docker-desktop_TIE_docker_registry HTTP/1.1" 201 88
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "GET /v1.40/containers/cb29124b4187aaca794535338fcd72538b4b63c09219ae65f67ecc865f13c95c/json HTTP/1.1" 200 None
DEBUG:urllib3.connectionpool:http://127.0.0.1:43725 "POST /v1.40/containers/cb29124b4187aaca794535338fcd72538b4b63c09219ae65f67ecc865f13c95c/start HTTP/1.1" 204 0
INFO:root:Proxy running on port 32771.
DEBUG:urllib3.connectionpool:http://localhost:None "POST /v1.41/images/sha256:2b5071999eb6b953f24c736781644e0717bf0d5435dc08b2022c5d47c760c8be/tag?tag=latest&repo=localhost%3A32771%2Fmyapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c&force=0 HTTP/1.1" 201 0
INFO:root:Pushing image to the registry.
DEBUG:urllib3.connectionpool:http://localhost:None "POST /v1.41/images/sha256:2b5071999eb6b953f24c736781644e0717bf0d5435dc08b2022c5d47c760c8be/tag?tag=latest&repo=localhost%3A49156%2Fmyapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c&force=0 HTTP/1.1" 201 0
DEBUG:docker.auth:Looking for auth config
DEBUG:docker.auth:No auth config in memory - loading from filesystem
DEBUG:docker.auth:Looking for auth entry for 'localhost:49156'
DEBUG:docker.auth:No entry found
DEBUG:docker.auth:No auth config found
DEBUG:urllib3.connectionpool:http://localhost:None "POST /v1.41/images/localhost:49156/myapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c/push?tag=latest HTTP/1.1" 200 None
INFO:root:The push refers to repository [localhost:49156/myapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c]
INFO:root:SSH - Connection to 07011707 closed
INFO:root:SSH - Tunnel to 07011707 closed
DEBUG:paramiko.transport:Ignoring message for dead channel 2
**ERROR:root:Error: 530 Local docker exception. Docker exception: Get "http://localhost:49156/v2/": dial tcp [::1]:49156: connect: connection refused**
**message:Get "http://localhost:49156/v2/": dial tcp [::1]:49156: connect: connection refused**
**The push refers to repository [localhost:49156/myapp-ux_arm64v8-qt5-vivante-no-ssh_bullseye_debug_c6249b4a-bf8f-4895-83e6-bfb4cac2102c]**
**INFO:root:REST <- /api/applications/c6249b4a-bf8f-4895-83e6-bfb4cac2102c/deploy - 53**0
INFO:root:REST -> /api/progress/delete
DEBUG:connexion.decorators.validation:http://localhost:5001/api/progress/delete?progress_id=6ba2115a-6d01-42f9-ac57-81d25cf5b068 validating parameters...
INFO:root:REST <- /api/progress/delete - 200
DEBUG:paramiko.transport:Received global request "keepalive@openssh.com"
DEBUG:paramiko.transport:Rejecting "keepalive@openssh.com" global request from server.
I don’t quite understand why it’s trying to push the image to a repository? I think I might have an incorrect configuration somewhere, but not sure where. I have tried a similar deploy/debug process on two different Windows 10 machines and it seems to work fine. Just not sure why a push is happening here.
Any ideas?
Thanks,
gabe
