So, loading the 2 binaries independently doesn’t quite work ![]()
I’ve split the binaries using objcopy :-
arm-none-eabi-objcopy -j .ncache -O binary “test” “test_data2.bin”;
arm-none-eabi-objcopy -R .ncache -O binary “test” “test_app.bin”;
(n.b. I also trest with --strip-debug but the outputs are the same as might be expected)
I can run the app from MCUXpresso, of course.
Then, if I reset the board (without a power cycle) and interrupt U-Boot, I can
fatload mmc 0:1 ${loadaddr} test_app.bin
bootaux ${loadaddr}
and the app still runs.
On the other hand the app does not run if I do the above after power cycle. This is expected - with a reset, the data is left in memory, whereas after a power cycle the memory is cleared, so the app finds nothing there.
This proves that the data2(.ncache) section has been removed from the test_app.bin.
Unfortunately I have not been able to load the test_data2.bin.
After a power cycle
fatload mmc 0:1 0x88000000 test_data2.bin
bootaux ${loadaddr}
the app doesn’t run. There are no obvious errors on the U-Boot console.
I use the address 88000000 because that’s the address of the memory region for m_data2 as specified in the linker script
MEMORY
m_interrupts (RX) : ORIGIN = 0x1FFE0000, LENGTH = 0x00000A00
m_text (RX) : ORIGIN = 0x1FFE0A00, LENGTH = 0x0001F600
m_data (RW) : ORIGIN = 0x20000000, LENGTH = 0x00020000
m_data2 (RW) : ORIGIN = 0x88000000, LENGTH = 0x08000000
.ncache :
*(.rodata) /* .rodata sections (constants, strings, etc.) */
*(.rodata*) /* .rodata* sections (constants, strings, etc.) */
*(NonCacheable)
. = ALIGN(4);
__noncachedata_end__ = .; /* define a global symbol at ncache data end */
} > m_data2
which, if I understand correctly, corresponds to DDR.
Also, my understanding is that there is some memory address difference between the U-Boot environment and the M4, in that the TCM addresses start from 1ffe0000 as seen from the M4, but this corresponds to 34fe0000 from U-Boot (“AP view”). As shown by bootaux.
However I haven’t found any address distinction for the DDR.
Is it correct that both M4 and U-Boot use the same addresses for the DDR ?
I did try fatload mmc 0:1 48000000 test_data2.bin after reading my way through this but that gave me ** Reading file would overwrite reserved memory **.
So now I’m a bit stuck.
