HI, we have to do A BIG production with boards that mount an APALIS IMX6Q.
We need to load software on all apalis imxq6 of each boards.
Normally, when we do it with 1 SOM for the first time we connect serial uart1 in order to use the console and load software.
With large numbers it is not possible because require a lot of time.
Is there any different way (for production) to load our software without connect uart1?
It describes how you can flash one image automatically once the system has detected its presence, for instance, by connecting a USB Key. Would this be a suitable solution for you?
Just as a check, the Toradex Easy Installer will allow you to upload your custom image with your own application to the module. This was what you meant, right?
