LinuxImage4.0
I’ve been trying to get the LinuxImage4.0 to work. I’ve followed this tutorial, but I’ve changed few commands to download the LinuxImage4.0.
I used
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImage4.0 -m default.xml
to initialize the repo’s repository, but upon building the image with the bitbake -k graphical-tdx-image, the kernel built is still on 4.19, which shouldn’t be the case, as the LinuxImage4.0, aka zeus, uses kernel 5.4.
Is there something I’m doing wrong or something I forgot to consider?
Hi
LinuxImage4.0 is still under development, so do not expect anything useful resulting from your builds and it is expected to be released in Q2.
Max
I do understand that, but I’m doing it just to test something out with the kernel versions.
What I was wondering about is, when I init the repo, I get that manifest.xml file, which should contain different branches that should be pulled (if I understood that correctly), but even with all of them set to zeus (default on LinuxImage4.0), warrior and thud are downloaded instead.
Would there be a way to bypass that?
Hi
Just to stress it again:
You could use the integration.xml manifest which checks out HEAD of the specified branches for meta-toradex-*. E.g.:
repo sync
Max
