I am getting compile error on LinuxImageV2.8 when building the console image:
bitbake console-tdx-image
Trying bitbake angstrom-lxde-image also gives the same errors.
Apparently, there is some issue in compiling imx-loader-native where usb-1.0 library cannot be found. I have attached the bitbake output log output and related log.do_compile for more info.
The only configuration I have done is the following in the local.conf which should be irrelevant:
I had some missing packages (specifically libusb-devel.i686 and libuuid-devel.i686) on my host system. Following instructions in this link solved the issue:
I did not. My bad. Installing them fixed this issue, thanks. We had built yocto images before on this server and I didn’t expect any missing prerequisites.
Another issue: Now I am getting errors with pattern of The recipe XX is trying to install files into a shared area when those files already exist where XX is base-files, volatile-binds, update-rc.d, shadow-securetty, etc, on a scratch bitbake console-tdx-image. Should I open a separate question?
