Linux video capture interface and device path on apalis-imx6
I’m trying to setup video capture on Apalis IMX6 development board with linux-toradex-mainline 6.1.0-rc5-0+git.094226ad94f4.
The problem is that many /dev/video* devices of class “Source/Video” are visible already before camera is connected so how to find when camera is really connected and which device path is for camera interface?
root@b2qt-apalis-imx6:~# v4l2-ctl --list-devices
imx-capture (platform:2400000.ipu):
        /dev/video1
        /dev/video2
imx-capture (platform:2800000.ipu):
        /dev/video5
        /dev/video6
imx-csc-scaler (platform:imx-csc-scaler):
        /dev/video8
imx-capture (platform:imx-ipuv3-csi.0):
        /dev/video0
imx-capture (platform:imx-ipuv3-csi.1):
        /dev/video3
imx-capture (platform:imx-ipuv3-csi.4):
        /dev/video4
imx-capture (platform:imx-ipuv3-csi.5):
        /dev/video7
All the video devices above have Device Caps for Video Capture:
root@b2qt-apalis-imx6:~# v4l2-ctl --device=/dev/video0 --all
Driver Info:
        Driver name      : imx-capture
        Card type        : imx-capture
        Bus info         : platform:imx-ipuv3-csi.0
        Driver version   : 6.1.0
        Capabilities     : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
I was thinking should these devices be registered in /dev/videoX only after camera is plugged or could Device Caps be Metadata Capture instead of Video Capture to ease filtering for actual camera?
Hi @arpa !
You could create a symlink to your specific camera device using a udev rule.
Example from StackOverflow: https://askubuntu.com/questions/783357/create-a-symlink-in-dev-using-etc-udev-rules
This way, you have control over the device’s symlink name on your OS.
Hello @arpa,
Were you able to solve your issue with the info from @henrique.tx ?
Josep
