We are using a customized yocto image based on the the toradex-manifest.
After upgrading our manifest from 50fbf92e2b38605d1e80d736eef763f91e480e4e to d62c42de093b248fbeecb4ace72b609ae2094a59 there is an issue with the names of the files produced by meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb. All names contain the string “AUTOINC”:
SPL-colibri-imx6-mender-2020.07+gitAUTOINC+4baed78646-r0-spl-2020.07+gitAUTOINC+4baed78646-r0
fw_env.config-colibri-imx6-mender-2020.07+gitAUTOINC+4baed78646-r0
imx6dl-colibri-aster--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.dtb
imx6dl-colibri-cam-eval-v3--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.dtb
imx6dl-colibri-eval-v3--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.dtb
imx6dl-colibri-iris--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.dtb
imx6dl-colibri-iris-v2--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.dtb
modules--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.tgz
u-boot-initial-env-colibri-imx6-mender-spl-2020.07+gitAUTOINC+4baed78646-r0
u-boot-spl-2020.07+gitAUTOINC+4baed78646-r0.img
zImage--5.4.193+gitAUTOINC+eb8d1c92da-r0.0-colibri-imx6-mender-20240315072744.bin
As this issue did not exist in commit 50fbf92e2b38605d1e80d736eef763f91e480e4e maybe you can help me to find out what modifications on your side caused this change of behavior and how I can fix this on my side.
Our *.bbappend file was based on recipes-kernel/linux/linux-toradex_5.4-2.1.x.bb and is now based on recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb.
To see the differences I used this line in meta-toradex-nxp:
git diff fa41855fb9a79718aa16b8e76b0255a40e8d16f3 -- recipes-kernel/linux/linux-toradex_5.4-2.1.x.bb d7075d95ca68661d0e95f5324a19e0397d6b1a45 -- recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb
But this shows no changes which seem to be relevant to this issue.
Seems like I solved it for linux-toradex (but I have still check if it has some unwanted side effects).
Inspired by commit b97a88c0cb100e059673cbcc75ac79ef0eb24f39 in meta-toradex-nxp I added this line to my recipes-kernel/linux/linux-toradex_5.4-2.3.x.bbappend file:
# Remove AUTOINC from PV="5.4.193+gitAUTOINC+498c1d54ef"
PV ="${LINUX_VERSION}+git${@'${SRCPV}'.replace('AUTOINC+', '')}"
And to recipes-bsp/u-boot/u-boot-toradex_%.bbappend:
# Remove AUTOINC from PV="2020.07+gitAUTOINC+4baed78646"
PV = "2020.07+git${@'${SRCPV}'.replace('AUTOINC+', '')}"
I could not find out which variable defines 2020.07, but for now it will do.
Hi @lmoellendorf !
From what you shared, you are using the head of dunfell-5.x.y, right?
This release is not tagged.
You should get fixed version strings (no AUTOINC) from tagged releases. For example, you could use toradex-manifest.git - Repo manifest for Toradex Embedded Linux TorizonCore and BSP layer setup for Yocto Project/Openembedded, which is currently the latest tagged release (5.7.5) for BSP 5.
Or, if possible for you, you could migrate to BSP 6
Do I understand correctly that AUTOINC is replaced if the the checked out manifest is tagged?
But if I base our custom manifest on yours, I get a merge commit “Merge tag ‘5.7.5’ into …” which is not tagged. So AUTOINC won’t be replaced in this case?
Could you please point me to a documentation of this AUTOINC feature is explained? And/or to the script where this AUTOINC replacement takes place?
I need to get a better understanding to decide how to proceed.
Hi @lmoellendorf !
To get more information about OpenEmbedded/Yocto/Bitbake, the best place is their documentation.
Here are some direct links I found:
Also, is it possible that you enabled the use-head-next in your build? As an example, from the link below, we can see that using it will enable the AUTOREV for SRCREV.
I enabled AUTOREV in our kernel’s *.bbappend for development.
Thanks for the links. I learned that I can add PRSERV_HOST = "localhost:0" to my local.conf in order to start the PR server. It works locally, but it does not work on our CI server.
For now I will use the workaround mentioned above.
