I have a VF50 running Linux 2.5. On the device, I have a single text file which contains system configuration information, such as ip address, network information and services that need to be enabled or disabled at boot up (such as ntp, ssh, ftp). I need to configure the system from this text file at boot.
I have written a C program that reads this text configuration file and creates the required system configuration files for networking and also calls systemctl to enable or disable the required services.
However, as a bit of a newby to Linux, I’m not exactly sure what my service file should look like in order to run this program after the file system is up, but before networking and any of the optional services have started.
I currently have the following service file, but it does not seem to work correctly:
[Unit]
Description=Load configuration files
After=local-fs.target
[Service]
Type=oneshot
ExecStart=/usr/sbin/configure
[Install]
WantedBy=multi-user.target
Any help on this would be most appreciated.
