Linux repo init not working
I am working on a Windows laptop with WSL2 running Ubuntu 20.04 LTS. I installed the “Required Packages for the Build Host”. I try to follow the setup for building a Linux OS on your page Build a Reference Image with Yocto Project.
I managed to install repo as suggested:
$  mkdir ~/bin
$  export PATH=~/bin:$PATH
$  curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
$  chmod a+x ~/bin/repo
Now, I am stuck with the “First-time Configuration” as suggested:
$ mkdir ${HOME}/oe-core
$ cd ${HOME}/oe-core
$ repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
$ repo sync
The (modified) command
$ repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.0.0 -m tdxref/default.xml
returns the error message
/usr/bin/env: ‘python’: No such file or directory
I think python is installed, it is version 3. The command python3 shows:
Python 3.8.5 (default, Jul 28 2020, 12:59:40)
[GCC 9.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
How can I get the repo init command running?
Maybe just sticking to some sane development environment would help?
https://www.yoctoproject.org/docs/1.8/yocto-project-qs/yocto-project-qs.html#packages
