I receive an error when compiling the toradex_4.1-2.0.x-imx branch for the Colibri iMX7. Here are the steps to hopefully reproduce the error.
Clean clone from
git clone -b toradex_4.1-2.0.x-imx git://git.toradex.com/linux-toradex.git
make colibri_imx7_defconfig
make -j3 zImage 2>&1 | tee build.log
Here is the following output from kernel compiling.
Notably,
arm-angstrom-linux-gnueabi-objcopy: arch/arm/vdso/vdso.so: Not enough room for program headers, try linking with -N
arm-angstrom-linux-gnueabi-objcopy:arch/arm/vdso/vdso.so[.hash]: Bad value
arch/arm/vdso/Makefile:45: recipe for target ‘arch/arm/vdso/vdso.so’ failed
make1: *** [arch/arm/vdso/vdso.so] Error 1
Makefile:948: recipe for target ‘arch/arm/vdso’ failed
make: *** [arch/arm/vdso] Error 2
A similar question was asked here
My Environment variables are set as recommended from the similar question.
echo $PATH
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/sbin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/bin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/sbin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/…/x86_64-angstromsdk-linux/bin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-uclibc:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-musl:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
echo $CROSS_COMPILE
I also follow the advice to directly force the use of the bfd linker.
make -j3 zImage LD=${CROSS_COMPILE}ld.bfd | tee build.log
With the same result.
If I build using openembedded it builds clean and runs as expected on the Colibri iMX7D
Any help would be appreciated.
