Linux BSP 3.0b2 USB wifi dongle isn't recognized anymore
After upgrading from BSP v2.8b6 to v3.0b2 my USB wifi dongle with a RTL8188CU isn’t recognize anymore.
This is the printout after plugging the dongle in:
v2.8b6:
[   18.821925] usb 1-1.3: new high-speed USB device number 5 using ci_hdrc
[   19.177468] usb 1-1.3: Vendor: Realtek
[   19.195614] usb 1-1.3: Product: 802.11n WLAN Adapter
[   19.214793] usb 1-1.3: rtl8192cu_parse_efuse: dumping efuse (0x80 bytes):
[   19.236210] usb 1-1.3: 00: 29 81 00 74 cd 00 00 00
[   19.255728] usb 1-1.3: 08: ff 00 da 0b 76 81 01 41
[   19.275033] usb 1-1.3: 10: 32 00 85 62 9e ad 80 1f
[   19.294139] usb 1-1.3: 18: 02 f2 c9 b7 0a 03 52 65
[   19.312558] usb 1-1.3: 20: 61 6c 74 65 6b 00 16 03
[   19.330518] usb 1-1.3: 28: 38 30 32 2e 31 31 6e 20
[   19.348189] usb 1-1.3: 30: 57 4c 41 4e 20 41 64 61
[   19.365668] usb 1-1.3: 38: 70 74 65 72 00 00 00 00
[   19.382957] usb 1-1.3: 40: 00 00 00 00 00 00 00 00
[   19.399969] usb 1-1.3: 48: 00 00 00 00 00 00 00 00
[   19.416496] usb 1-1.3: 50: 00 00 00 00 00 00 00 00
[   19.432436] usb 1-1.3: 58: 06 00 25 25 25 00 00 00
[   19.447914] usb 1-1.3: 60: 27 27 27 00 00 00 00 00
[   19.463043] usb 1-1.3: 68: 00 00 00 00 11 11 33 00
[   19.477775] usb 1-1.3: 70: 00 00 00 00 00 02 00 00
[   19.491945] usb 1-1.3: 78: 0e 00 00 00 36 00 00 00
[   19.505779] usb 1-1.3: RTL8188CU rev A (TSMC) 1T1R, TX queues 2, WiFi=1, BT=0, GPS=0, HI PA=0
[   19.533145] usb 1-1.3: RTL8188CU MAC: 80:1f:02:f2:c9:b7
[   19.547996] usb 1-1.3: rtl8xxxu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[   19.574570] usb 1-1.3: Firmware revision 80.0 (signature 0x88c1)
[   20.423840] wlan0: authenticate with XX:XX:XX:XX:XX:XX
[   20.448117] wlan0: send auth to XX:XX:XX:XX:XX:XX (try 1/3)
[   20.468903] wlan0: authenticated
[   20.491898] wlan0: associate with XX:XX:XX:XX:XX:XX (try 1/3)
[   20.516678] wlan0: RX AssocResp from XX:XX:XX:XX:XX:XX (capab=0x431 status=0 aid=4)
[   20.546136] usb 1-1.3: rtl8xxxu_bss_info_changed: HT supported
[   20.565734] wlan0: associated
v3.0b2
[   38.401346] usb 1-1.3: new high-speed USB device number 6 using ci_hdrc
Do I have to enable some specific driver in the kernel?
Hi @Mowlwurf
We removed the backports driver in Bsp 3.0b2 as they are not needed anymore. Unfortunately the RTL8188x needs one of these drivers.
We will look into this issue and try to fix this soon.
Are there any news about this?
Best regards
HI @Mowlwurf
Unfortunately no. How many Wifi Dongles with the Realtek chip have you in use?
At the moment we have two RTL8192-dongles with the Colibri Eval Board in use. Two more are ready in the drawer.
Can you recommand a wifi chip which works for BSP 2.8 and 3.0?
Hi @Mowlwurf
One of our customer is using this. Maybe you try this.
For the feature, we will test some Intel/Braodcom chip based USB or PciE cards and update our list of tested wifi Dongles.
