Which Cross compiler should be used for Linux Application Development with above Toradex Modules
Which gives better executable.
- Cross compiler provided in SDK
or - Linaro Cross compiler
Hi @zecons
Which Cross compiler should be used for Linux Application Development with above Toradex Modules Which gives better executable.
What do you mean with better executable?
You can use both compiler for your Linux Application Development, but depending on your needs, it may be necessary to create a special SDK with the library needed for your application. You might have a look here and here to get knowledge about differences between a SDK and the Linaro ToolsChain.
