I sorely need some features from 4.1 and I’m checking my options. I noticed that there are no devicetree files for imx6-colibri in your toradex_imx_4.1.15_1.0.0_ga branch but I’m trying to make it work anyway by copying dts files from the 3.14.52 branch (is that a bad idea?).
Do you expect to release linux 4.1 for the imx6 colibri in the coming month?
@gardarh If you are not looking for hardware acceleration and just want a more mainlinish kernel, you can try the for-next branch. Colibri iMX6 was recently added with this commit.
I’m running into problems with starting the 4.9 kernel when I copy the compiled uImage along with the dtb to the boot partition when otherwise using the the rootfs from the Toradex 2.6.1. Here is what I get on my console:
U-Boot 2015.04+fslc+g46aa70c (Sep 29 2016 - 21:49:17)
CPU: Freescale i.MX6DL rev1.2 at 792 MHz
CPU: Temperature 52 C
Reset cause: WDOG
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x11
PMIC: programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.0A, Serial# 04869065
Net: using PHY at 0
FEC [PRIME]
Normal Boot
Booting from internal eMMC chip...
reading imx6dl-colibri-eval-v3.dtb
42953 bytes read in 17 ms (2.4 MiB/s)
reading uImage
5032128 bytes read in 145 ms (33.1 MiB/s)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-4.1.15-00015-g106d911-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5032064 Bytes = 4.8 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200d7c8
Starting kernel ...
@sanchayn.tx Ugh, I forgot to modify my deployment script and it was always picking up a kernel from an incorrect location. I managed to get this up and running. One thing is odd though, it complained that it didn’t find mmcblk0p2 as the root device, so I did the following in uBoot:
@sanchayn.tx Is this move from mmcblk0 to mmcblk1 something that will also occur on the Toradex branch? This causes a lot of small issues, one of the being that
fw_setenv needs to be modified.
@sanchayn.tx I think just using mmcblk?boot0 in the fw_unlock_mmc.sh script would work in case you want the Toradex layer to be compatible with the mainline kernel.
