Link of nv_omx_h264enc and rtph264pay
There is the GStreamer examples in this URL.
http://developer.toradex.com/knowledge-base/video-playback-(linux)
This example works.
gst-launch -v filesrc location=temp.mp4 ! qtdemux name=demux demux.video_00 ! queue ! rtph264pay pt=96 ! udpsink host=localhost port=5000 demux.audio_00 ! queue ! rtpmp4apay pt=97 ! udpsink host=localhost port=5001
But I want to use camera input.
I tried this example, too.
gst-launch-0.10 -e v4l2src device="/dev/video0" ! ‘video/x-raw-yuv, width=(int)640, height=(int)480, format=(fourcc)YUY2’ ! nvvidconv ! ‘video/x-nvrm-yuv, format=(fourcc)I420’ ! nv_omx_h264enc ! rtph264pay pt=96 ! udpsink host=localhost port=5000
This example doesn’t works.
console logs:
root@colibri-t20:~# gst-launch-0.10 -e v4l2src device="/dev/video0" ! ‘video/x-raw-yuv, width=(int)640, height=(int)480, format=(fourcc)YUY2’ ! nvvidconv ! ‘video/x-nvrm-yuv, format=(fourcc)I420’ ! nv_omx_h264enc ! rtph264pay pt=96 ! udpsink host=localhost port=5000
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 4
NvRmPowerModuleClockControl on MOD[29] INST[0]
NvRmModuleResetWithHold deassert MOD[29] INST[0]
NvMMLiteBlockCreate : Block : BlockType = 4
+NvxVideoEncoderSetNvMMAttributes-NvxVideoEncoderSetNvMMAttributesERROR: from element /GstPipeline:pipelin[ 3582.022780] misc knvmap: nvmap_unpin_ids: gst-launch-0.10 unpinning unpinned handle cc84d2e0
e0/GstRtpH264Pay[ 3582.036307] misc knvmap: nvmap_unpin_ids: gst-launch-0.10 unpinning unpinned handle cc84d360
:rtph264pay0: Element doesn’t implement handling of this stream. Please file a bug.
Additional debug info:
/home/user1/work/oe-core/build/out-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/gst-plugins-base/0.10.36-r8/gst-plugins-base-0.10.36/gst-libs/gst/rtp/gstbasertppayload.c(850): gst_basertppayload_prepare_push (): /GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0:
subclass did not specify clock-rate
Execution ended after 377957000 ns.
Setting pipeline to READY …
NvRmPowerModuleClockControl off MOD[29] INST[0]
Setting pipeline to NULL …
Freeing pipeline …
root@colibri-t20:~#
It is a same result even if I use "videotestsrc”.
So this isn’t camera issue.
gst-launch-0.10 -e videotestsrc ! ‘video/x-raw-yuv, width=(int)640, height=(int)480, format=(fourcc)YUY2’ ! nvvidconv ! ‘video/x-nvrm-yuv, format=(fourcc)I420’ ! nv_omx_h264enc ! rtph264pay pt=96 ! udpsink host=localhost port=5000
Is this a bug?
Best regards.
Please have a look at the following article on our developer website.
It seems that rtph264pay requires alignment=nal.
So try following pipeline
… ! nv_omx_h264enc ! ‘video/x-h264,stream-format=byte-stream,alignment=nal’ ! rtph264pay …
Thanks for your replay.
I was able to achieve a purpose with “alignment=nal”
I wish Example is modified.
Best regards.
