Please provide us the details of list of accessories that we get when we buy Ixora carrier board. Can you please list one by one?
Also please provide the hyperlink.
I was looking at Unboxing and Setup Cables - Ixora Carrier Board and a bit worried.
Also please confirm, is there any possible way to communicate to PC other than IDC-DB9 cable?
Thanks,
Sridhar
Dear @sridhar.jonnavittula ,
Thank you for contacting the Toradex Community!
The following flyer gives a list of all the Acessories you would need for your Ixora Carrier board:
The Carrier Board Accessory kit comes as one single package and you can order it in the following link:
IDC- DB9 is the way to communicate with the Ixora and it is the recommended one.
Thank you and Regards,
Janani.
Hi @sridhar.jonnavittula
Is connecting to X22 mandatory or can we use X21 UART2 instance also?
X22 is our default UART-1 Interface for debugging. But you can use the UART2 too, you just to change the console output to a different UART as explained here.
Can a USB FTDI cable with four pins(RTS,CTS,TXD,RXD) be used?
For UART2 yes, for UART3 no, since there are only two pins (TXD, RXD) available on the connector X21.
Hi @jaski.tx ,
Could you please prefer USB to RS232 6 pin cable for UART1 instance(X22) from any manufacturer for our kitting?
Thanks,
Sridhar
I don’t understand your question.
For UART1 is RTS/CTS is enabled or disabled by default and how to know that?
Hi
As described in our article about UART, RTS/CTS is enabled for UART1.
