We are currently porting our WinEC7 based application to Linux (own distribution). In order to work around some layout weaknesses we have to limit the SD clock speed over the WinEC7 registry to 25MHz (Colibri/Apalis i.MX6 SD card interface). This is the only way to detect SD cards without any problems.
Is it possible to limit the SD clock speed to 25MHz under Linux? How/where can this be done?
PS: This is a follow up ticket of Some SD cards not detected - Technical Support - Toradex Community
