Based on the context provided, it seems like you are experiencing issues with accessing your board via IP and encountering a USB-related error. The problem could be either software or hardware-related, but without more specific information, it’s difficult to determine the exact cause.
Here are some steps you can take to troubleshoot:
Network Configuration: Ensure that the board is properly connected to the network. You can use tools like
arp-scanon Linux ornmapon Windows to verify if the board’s IP address is visible on the network. -
USB Connection: Check the USB connection to ensure it is secure and that the correct drivers are installed on your host machine. If the USB connection is not stable, it might cause issues with accessing the board.
SSH Configuration: If you are trying to access the board via SSH, ensure that the SSH service is running on the board. You can check the SSH service status using
journalctlfor any related log messages. -
Serial Console Access: If network access is not possible, try accessing the board via a serial terminal emulator like Picocom, Minicom, or Putty to check the board’s status and configuration.
Hardware Check: If none of the above steps resolve the issue, there might be a hardware problem. Check the board for any visible damage or loose connections.
If these steps do not help in identifying the issue, further investigation with more detailed logs or error messages would be necessary to pinpoint the problem.
