Hardware:
Colibri iMX6DL
with Viola Carrier Board Rev 1.2
TorizonCore 5.7.2
Hi there,
We have a LCD display + Resistive Touch connected via the Unified Interface Display Connector (X7). The LCD display is working with the required device tree overlay support.
And the touch is enabled with the ‘colibri-imx6_stmpe-ts_overlay.dts’ file
$ ls -al /dev/input
$ udevadm info /dev/input/event0
$ cat /etc/udev/rules.d/touchscreen.rules
$ evtest
$ docker run -ti --rm -e ACCEPT_FSL_EULA=1 -e DISPLAY=DPI-1 --privileged -v /dev:/dev -v /run/udev/:/run/udev/ -v /etc/udev/rules.d:/etc/udev/rules.d torizon/weston-touch-calibrator:$CT_TAG_WESTON_TOUCH_CALIBRATOR
All that seems to be working ok, but then when I run a weston container…
There seems to be some issues…
“input device event0 has no enabled output associated”
And the touch doesn’t seem to work on this display
Not sure if its related to…
Let me know if you have any more details to resolve the issue.
