Hi @Mehrdad !
Thanks for the clarification.
Can you please share the output of sudo tdx-info --all on your module?
Hi @Mehrdad !
Hi @henrique.tx ,
Please see the attached file the output summary.
device summary.txt (39.4 KB)
Best,
Mehrdad
Hi @Mehrdad !
Thanks for the file.
From that, we can see that you are still using the default (pre-enabled) device trees and your overlays are not enabled.
Device tree overlays
Overlays enabled: fdt_overlays=verdin-imx8mm_dsi-to-hdmi_overlay.dtbo verdin-imx8mm_spidev_overlay.dtbo
After you build the image, arenāt you installing it to the module?
Please check the deployment section of the Workflow article
Hi @henrique.tx ,
If youāre asking about deployment, hereās what I did on Ubuntu.
The last command, from the output directory, shows that the image was successfully deployed to my SOM.
Mehrdad
Hi @Mehrdad !
Sorry. I forgot you shared it already.
Before I thought it was only the device tree overlays being enabled. But, as you noted, the pending state might be the issue that is causing your updates to not take place.
I will need to check if I can reproduce it, which could be a bug.
Could you please share the version of TorizonCore Builder that you are using?
Please share the output of
torizoncore-builder --version
and
docker images | grep torizoncore-builder
Thank you so much @henrique.tx .
torizoncore-builder --version: torizoncore-builder 3.7.0
and
docker images | grep torizoncore-builder: torizon/torizoncore-builder 3
d67833aab937 3 months ago 958MB
Mehrdad
Hi @Mehrdad !
I just tested and I could not reproduce the strange behavior you are getting.
I used the same TorizonCore Builder version (same hash):
$ docker images | rg torizoncore-builder
torizon/torizoncore-builder 3 d67833aab937 3 months ago 958MB
I used the following tcbuild.yaml:
input:
easy-installer:
local: torizon-core-docker-verdin-imx8mm-Tezi_6.2.0+build.2
customization:
device-tree:
include-dirs:
- linux-toradex_5.15-2.1.x-imx/include/
- linux-toradex_5.15-2.1.x-imx/arch/arm64/boot/dts/freescale
overlays:
clear: true
add:
- enable-led.dtso
output:
easy-installer:
local: output_directory
Notes:
linux-toradex on branch toradex_5.15-2.1.x-imx (I am specifically on commit a918eab4e464ddbdca90b4837ef9a3fc20ead058) from linux-toradex.git - Linux kernel for Apalis, Colibri and Verdin modulesContent of enable-led.dtso:
/dts-v1/;
/plugin/;
#include <dt-bindings/leds/common.h>
#include "imx8mm-pinfunc.h"
compatible = "toradex,verdin-imx8mm";
leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_my_led>;
myled_sodimm_19 {
label = "my_led_sodimm_19";
gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
default-state = "on";
myled_sodimm_55 {
label = "my_led_sodimm_55";
gpios = <&gpio5 16 GPIO_ACTIVE_HIGH>;
&pwm1 {
status = "disabled";
&pwm2 {
&iomuxc {
/*pinctrl-0 = <&pinctrl_gpio1>, <&pinctrl_gpio2>,
<&pinctrl_gpio3>, <&pinctrl_gpio4>,
<&pinctrl_gpio7>, <&pinctrl_gpio8>,
<&pinctrl_gpio_hog1>, <&pinctrl_gpio_hog2>, <&pinctrl_gpio_hog3>,
<&pinctrl_pmic_tpm_ena>, <&pinctrl_my_led>;*/
pinctrl_my_led: myledgrp {
fsl,pins =
<MX8MM_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x104>, // SODIMM 19 // pull-down enabled and drive strength X2
<MX8MM_IOMUXC_I2C2_SCL_GPIO5_IO16 0x104>; // SODIMM 55 // pull-down enabled and drive strength X2
After using the build command, I unpacked the image from the output_directory and deployed it using torizoncore-builder just like you did;
torizoncore-builder build
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Copying Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision 8fcecdceae5e7e70f0d852eea6d97f940ea0196849d6461cbd665312ca43a3ba from local repository...
957 metadata, 9227 content objects imported; 579.3 MB content written
Unpacked OSTree from Toradex Easy Installer image:
Commit checksum: 8fcecdceae5e7e70f0d852eea6d97f940ea0196849d6461cbd665312ca43a3ba
TorizonCore Version: 6.2.0+build.2
=>> Handling customization section
=> Handling device-tree subsection
Not testing overlay because base image does not have a device-tree set!
=> Adding device-tree overlay 'enable-led.dtso'
'enable-led.dtso' compiles successfully.
Overlay enable-led.dtbo successfully applied.
=>> Handling output section
Applying changes from STORAGE/dt.
Commit 49555272dd3a213e1283aaecbd6da1046fe299814d4ffcf90cb639276939b33f has been generated for changes and is ready to be deployed.
Deploying commit ref: tcbuilder-20230616081638
Pulling OSTree with ref tcbuilder-20230616081638 from local archive repository...
Commit checksum: 49555272dd3a213e1283aaecbd6da1046fe299814d4ffcf90cb639276939b33f
TorizonCore Version: 6.2.0+build.2-tcbuilder.20230616081638
Default kernel arguments: quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
957 metadata, 9228 content objects imported; 579.3 MB content written
Pulling done.
Deploying OSTree with checksum 49555272dd3a213e1283aaecbd6da1046fe299814d4ffcf90cb639276939b33f
Deploying done.
Copy files not under OSTree control from original deployment.
Packing rootfs...
Packing rootfs done.
Updating TorizonCore image in place.
=>> Build command successfully executed!
$ torizoncore-builder images unpack output_directory/
Storage not empty. Delete current image before continuing? [y/N] y
Importing OSTree revision 49555272dd3a213e1283aaecbd6da1046fe299814d4ffcf90cb639276939b33f from local repository...
$ torizoncore-builder deploy --remote-password 1 --remote-host verdin-imx8mm-06827711 --reboot
Pulling OSTree with ref base (checksum 49555272dd3a213e1283aaecbd6da1046fe299814d4ffcf90cb639276939b33f) from local archive repository...
Starting http server to serve OSTree.
OSTree server listening on "localhost:35401".
Starting OSTree pull on the device...
Deploying new OSTree on the device...
Deploying successfully finished.
Device reboot initiated...
And here is the result:
It is working for me.
Is it possible that you are missing some steps?
Could you please try following what I did here?
Hi @henrique.tx ,
It doesnāt make sense why itās not working on my end!
Iām considering reflashing the System-on-Module (SoM) and starting from scratch. What would be the easiest test to perform?
If I disable the UART, would it be a good idea to check if the Device Tree is modifiable after deploying the image? I donāt want to test SPI or add overlays or other things.
What do you think about disabling UART 3 for example, and observing the outcome? Also, I am going to share all the details from the beginning ![]()
Mehrdad
Dear @henrique.tx ,
I hope you are doing well.
I wanted to express my sincere gratitude for the meeting we had regarding my case. ![]()
Your support and assistance were invaluable in resolving the issues I was facing. I truly appreciate the time you dedicated to helping me.
I am pleased to inform you that, with your guidance, I have successfully added a second SPI, disabled the PWMs and QSPI, and modified the device tree accordingly. These changes have greatly improved the functionality of the board, and I am thrilled with the results ![]()
However, I have encountered a new challenge. Upon enabling UART4, the board restarts by itself. I have tried reflashing it, but the issue persists. As this seems to be a separate problem, I will be opening a new ticket to address this specific issue.
Thank you again for your expertise and support. ![]()
Mehrdad
Hi @Mehrdad !
Thanks a lot for the feedback ![]()
It is always rewarding to be able to help.
Thanks a lot for your kind words towards our support ![]()
Please create the related new thread so we can take a closer look and try to reproduce the issue.
Have a nice day!
