Hi
We are currently trying to update our T30 modules to the latest version (2.4.b2).
We use the following procedure:
1: Flash with latest stock image
2: Install Compact Framework
3: Change needed configurations in registry
4: Copy needed files to the FlashDisk
5: Make a full backup of the module
But if we try to update this backup to another T30 module we get an error.
A command prombt with the text: syntax error (42): [
When closed the update tool show this error dialog: UDLDoUpdate: NvFlash Error
I cant attach pictures to this post? I get a “Error parsing file”?
This is the log from the UpdateTool:
UpdateTool 6.0.19 (2.0.18)
Colibri T30 1GB V1.1E SerialNo: 2905842
BCT V1.0 (800 Mhz)
First Bootloader (in Flash)
Ver: 2.4b2 (TEGRA)
Built: 16 Feb 2020 15:19:19 PM (GMT)
Second Bootloader (in Flash)
Ver: 2.4b2 (TEGRA)
Image (current running)
Ver: 2.4b2 (CE 8.0, TEGRA)
Built: 16 Feb 2020 15:11:35 PM (GMT)
Loaded \USB HD\MPC2 update\winceupdatetool_6.0.19\CE8\nvflash.dll
Nvflash version 2.6 started
Loaded \USB HD\MPC2 update\winceupdatetool_6.0.19\CE8\Nv3pServer.dll
System Information:
chip name: unknown
chip id: 0x30 major: 1 minor: 3
chip sku: 0x12
chip uid: 0x0000000000000000015d4a5edd041e04
macrovision: enabled
hdcp: enabled
jtag: enabled
sbk burned: true
dk burned: unknown
boot device: unknown
operating mode: 3
device config strap: 1
device config fuse: 0
sdram config strap: 0
MAC: TID=0x00142D, CID=2905842
HW: VerMaj=1, VerMin=1, Variant=4, ProdID=23
PROD: TestDay=738315, Testing=0, TestVer=53
Updating BCT
Sending generated BCT...RamSize=1024MB, isApalis=0, isIT=0, 800Mhz Done
file not found: Master
Sending Sync...
Sync Successful
command failure: create failed
Tried on two different units.
Thomas
