There is only 4GB as storage in Windows 10 IoT starter kit of Toradex. It is an error in the capacity shortage and to place the UWP. Connect the USB, Why is not there a way to use this as a storage? Also SD slot but comes with, or would not be able to recognize the MicroSD as storage? Provide thank you for information.
Thanks.
i can not place the app to use the USB memory. How us to recognize the USB as storage?
Thanks.
The external SD Card is not supported at the moment, we will add this feature in near future.
The USB Memory thumb drive should work does work.
Can you access it via SSH, and just need instructions how to use it as application storage for UWP?
Probably Yes, " just need instructions how to use it as application storage for UWP?"
I want teach me how to use it as application storage for UWP.
In the first image V0.0.1 the data Partition mounted to c:\data only left about 340MB for user applications. We will change this to several GB in next image which should be available within this week. For a workaround see this question.
Edit: To use the updated image follow this Flashing instructions
By all means, I want you to prepare a number GB of storage.
