The best way to solve this would be to patch the ASIX USB Ethernet driver as follows:
diff --git a/drivers/net/usb/asix.h b/drivers/net/usb/asix.h
index 9a4171b90947..c8161960cef2 100644
--- a/drivers/net/usb/asix.h
+++ b/drivers/net/usb/asix.h
@@ -37,6 +37,7 @@
#include <linux/usb/usbnet.h>
#include <linux/slab.h>
#include <linux/if_vlan.h>
+#include <linux/of_net.h>
#define DRIVER_VERSION "22-Dec-2011"
#define DRIVER_NAME "asix"
diff --git a/drivers/net/usb/asix_devices.c b/drivers/net/usb/asix_devices.c
index 3d4f7959dabb..de88cb8087cc 100644
--- a/drivers/net/usb/asix_devices.c
+++ b/drivers/net/usb/asix_devices.c
@@ -690,25 +690,32 @@ static int ax88772_bind(struct usbnet *dev, struct usb_interface *intf)
u8 buf[ETH_ALEN], chipcode = 0;
u32 phyid;
struct asix_common_private *priv;
+ const u8 *mac_addr;
- usbnet_get_endpoints(dev,intf);
+ usbnet_get_endpoints(dev, intf);
- /* Get the MAC address */
- if (dev->driver_info->data & FLAG_EEPROM_MAC) {
- for (i = 0; i < (ETH_ALEN >> 1); i++) {
- ret = asix_read_cmd(dev, AX_CMD_READ_EEPROM, 0x04 + i,
- 0, 2, buf + i * 2, 0);
- if (ret < 0)
- break;
+ /* Maybe the boot loader passed the MAC address via device tree */
+ mac_addr = of_get_mac_address(dev->udev->dev.of_node);
+ if (mac_addr) {
+ memcpy(buf, mac_addr, ETH_ALEN);
} else {
- ret = asix_read_cmd(dev, AX_CMD_READ_NODE_ID,
- 0, 0, ETH_ALEN, buf, 0);
+ /* Try getting the MAC address from EEPROM */
+ if (dev->driver_info->data & FLAG_EEPROM_MAC) {
+ for (i = 0; i < (ETH_ALEN >> 1); i++) {
+ ret = asix_read_cmd(dev, AX_CMD_READ_EEPROM, 0x04 + i,
+ 0, 2, buf + i * 2, 0);
+ if (ret < 0)
+ break;
+ } else {
+ ret = asix_read_cmd(dev, AX_CMD_READ_NODE_ID,
+ 0, 0, ETH_ALEN, buf, 0);
- if (ret < 0) {
- netdev_dbg(dev->net, "Failed to read MAC address: %d\n", ret);
- return ret;
+ if (ret < 0) {
+ netdev_dbg(dev->net, "Failed to read MAC address: %d\n", ret);
+ return ret;
asix_set_netdev_dev_addr(dev, buf);
Then combine it with a device tree patch as follows:
diff --git a/arch/arm/boot/dts/tegra30-colibri.dtsi b/arch/arm/boot/dts/tegra30-colibri.dtsi
index c44d8c40c410..1c911a5ed64a 100644
--- a/arch/arm/boot/dts/tegra30-colibri.dtsi
+++ b/arch/arm/boot/dts/tegra30-colibri.dtsi
@@ -439,11 +439,17 @@
/* EHCI instance 1: USB2_DP/N -> AX88772B */
usb@7d004000 {
+ #address-cells = <1>;
+ #size-cells = <0>;
+ asix@1 {
+ reg = <1>;
+ local-mac-address = [00 00 00 00 00 00];
usb-phy@7d004000 {
- nvidia,is-wired = <1>;
+ vbus-supply = <&lan_vbus_reg>;
clocks {
@@ -503,6 +509,17 @@
regulator-max-microvolt = <5000000>;
regulator-always-on;
+ lan_vbus_reg: regulator@104 {
+ compatible = "regulator-fixed";
+ reg = <104>;
+ regulator-name = "LAN_V_BUS";
+ regulator-min-microvolt = <5000000>;
+ regulator-max-microvolt = <5000000>;
+ enable-active-high;
+ gpio = <&gpio TEGRA_GPIO(DD, 2) GPIO_ACTIVE_HIGH>;
+ vin-supply = <&charge_pump_5v0_reg>;
sound {
@@ -521,3 +538,13 @@
clock-names = "pll_a", "pll_a_out0", "mclk";
+&gpio {
+ lan_reset_n {
+ gpio-hog;
+ gpios = <TEGRA_GPIO(DD, 0) GPIO_ACTIVE_HIGH>;
+ output-high;
+ line-name = "LAN_RESET#";
And have U-Boot fill it all in as follows:
diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c
index 8ae3437a49..a93db58124 100644
--- a/board/toradex/colibri_t30/colibri_t30.c
+++ b/board/toradex/colibri_t30/colibri_t30.c
@@ -12,6 +12,7 @@
#include <asm/gpio.h>
#include <asm/io.h>
#include <i2c.h>
+#include <fdt_support.h>
#include "pinmux-config-colibri_t30.h"
#include "../common/tdx-common.h"
@@ -36,6 +37,17 @@ int checkboard(void)
#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP)
int ft_board_setup(void *blob, bd_t *bd)
+ uint8_t enetaddr[6];
+ fdt_shrink_to_minimum(blob, 0); /* Make room for new properties */
+ /* MAC addr */
+ if (eth_getenv_enetaddr("ethaddr", enetaddr)) {
+ fdt_find_and_setprop(blob,
+ "/usb@7d004000/asix@1",
+ "local-mac-address", enetaddr, 6, 1);
return ft_common_board_setup(blob, bd);
#endif
This has been tested with today’s linux-next and our U-Boot 2016.11.
