A kernel panic occurs while booting tdx-reference-minimal-image with NFS/TFTP in DHCP mode.
The firmware:
git remote: Index of /toradex-manifest.git
git tag: 5.7.0-devel-202206
U-Boot command used after stopping auto-boot:
env set nfs_dhcp ‘\
dhcp && \
env set serenv set serverip 10.10.0.100 && \
env set fdtfile imx8mm-verdin-nonwifi-dev.dtb && \
env set kernel_image Image.gz && \
env set root_devtype && \
env set boot_devtype tftp && \
env set devtype dhcp && \
env set rootpath ${serverip}:/srv/nfs/rootfs/ca7,vers=3 && \
tftp ${scriptaddr} boot.scr && \
source ${scriptaddr}’
run nfs_dhcp
Using the following command in boot.scr
env set rootfsargs_set ‘env set rootfsargs “root=/dev/nfs ip=dhcp nfsroot=${rootpath}”’
instead of
env set rootfsargs_set ‘env set rootfsargs “root=/dev/nfs ip=dhcp”’
solved the problem.
Petr
