I followed the instructions from here to evaluate the M4 processor on my brand-new Colibri MX7 board.
Whenever i load a demo program in u-boot i can see the M4s debug output on my console. However when i attempt to boot the linux system i get the kernel panic below (even with the very simple hello_world example). The pre-installed image version is “Colibri-iMX7_LXDE-Image 2.7.2 20170410”.
I read that i have to take care to not use resources with both CPUs. Could this be the reason? Do i need to compile the kernel by my own and to edit the device tree?
Thaks for help!
Booting from NAND...
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd1 (name "mtd=4", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
Read 0 bytes from volume kernel to 81000000
No size specified -> Using max size (5113344)
Read 0 bytes from volume dtb to 82000000
No size specified -> Using max size (43480)
Kernel image @ 0x81000000 [ 0x000000 - 0x4e0600 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 8200d9d7
Updating MTD partitions...
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.39-2.7.2+gba2f75f (linuxdev@linuxdev.toradex.int) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #3 SMP Mon Apr 10 03:50:20 CE7
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri iMX7D on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0x86000000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 12 pages/cpu @8fb82000 s16844 r8192 d24116 u49152
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64516
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 116668K/260096K available (6406K kernel code, 285K rwdata, 2152K rodata, 312K init, 380K bss, 12356K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80863cc0 (8560 kB)
[ 0.000000] .init : 0x80864000 - 0x808b2000 ( 312 kB)
[ 0.000000] .data : 0x808b2000 - 0x808f94c0 ( 286 kB)
[ 0.000000] .bss : 0x808fc000 - 0x8095b16c ( 381 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000006] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000018] Switching to timer-based delay loop, resolution 125ns
[ 0.000452] mxc_clocksource_init 3000000
[ 0.000464] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000481] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001642] Console: colour dummy device 80x30
[ 0.002270] console [tty1] enabled
[ 0.002296] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.002338] pid_max: default: 32768 minimum: 301
[ 0.002455] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002483] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003111] Initializing cgroup subsys freezer
[ 0.003150] Initializing cgroup subsys debug
[ 0.003202] CPU: Testing write buffer coherency: ok
[ 0.003503] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.005441] Brought up 2 CPUs
[ 0.005473] SMP: Total of 2 processors activated (32.00 BogoMIPS).
[ 0.005495] CPU: All CPU(s) started in SVC mode.
[ 0.006016] devtmpfs: initialized
[ 0.019095] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.019493] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.019555] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.025579] pinctrl core: initialized pinctrl subsystem
[ 0.026817] NET: Registered protocol family 16
[ 0.032674] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.060384] cpuidle: using governor ladder
[ 0.090402] cpuidle: using governor menu
[ 0.103815] DDR type is DDR3!
[ 0.111067] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[ 0.111156] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.111191] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.111536] imx7d-pinctrl 30270000.lpsr-gpr: initialized IMX pinctrl driver
[ 0.111736] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.112993] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.114642] MU is ready for cross core communication!
[ 0.124376] mxs-dma 33000000.dma-apbh: initialized
[ 0.126212] VCC_USB[1-4]: supplied by 5V
[ 0.126682] SCSI subsystem initialized
[ 0.127008] usbcore: registered new interface driver usbfs
[ 0.127102] usbcore: registered new interface driver hub
[ 0.127225] usbcore: registered new device driver usb
[ 0.127489] 30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[ 0.127785] 30800000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
[ 0.128807] i2c i2c-0: IMX I2C adapter registered
[ 0.128840] i2c i2c-0: can't use DMA
[ 0.129330] i2c i2c-3: IMX I2C adapter registered
[ 0.129361] i2c i2c-3: can't use DMA
[ 0.129490] Linux video capture interface: v2.00
[ 0.129561] pps_core: LinuxPPS API ver. 1 registered
[ 0.129584] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.129643] PTP clock support registered
[ 0.130169] Advanced Linux Sound Architecture Driver Initialized.
[ 0.131564] Switched to clocksource arch_sys_counter
[ 0.142572] NET: Registered protocol family 2
[ 0.143404] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.143467] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.143527] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.143602] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.143652] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.143835] NET: Registered protocol family 1
[ 0.144153] RPC: Registered named UNIX socket transport module.
[ 0.144182] RPC: Registered udp transport module.
[ 0.144203] RPC: Registered tcp transport module.
[ 0.144224] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.146229] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.146354] imx rpmsg driver is registered.
[ 0.147327] Bus freq driver module loaded
[ 0.155320] VFS: Disk quotas dquot_6.6.0
[ 0.155545] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.157466] NFS: Registering the id_resolver key type
[ 0.157533] Key type id_resolver registered
[ 0.157555] Key type id_legacy registered
[ 0.157592] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.158132] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.158618] fuse init (API version 7.23)
[ 0.162246] io scheduler noop registered
[ 0.162284] io scheduler deadline registered
[ 0.162488] io scheduler cfq registered (default)
[ 0.164468] backlight supply power not found, using dummy regulator
[ 0.166465] 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.232043] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 0.240421] Console: switching to colour frame buffer device 80x30
[ 0.258139] mxsfb 30730000.lcdif: initialized
[ 0.260952] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 0.262785] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 0.267628] imx-sdma 30bd0000.sdma: initialized
[ 0.270407] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 280, base_baud = 1500000) is a IMX
[ 0.990153] console [ttymxc0] enabled
[ 0.996235] Unhandled fault: external abort on non-linefetch (0x1008) at 0xa08c0090
[ 1.007387] pgd = 80004000
[ 1.011842] [a08c0090] *pgd=8e000811, *pte=30890653, *ppte=30890453
[ 1.019987] Internal error: : 1008 [#1] SMP ARM
[ 1.026284] Modules linked in:
[ 1.031104] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.1.39-2.7.2+gba2f75f #3
[ 1.041950] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 1.049553] task: 8e058000 ti: 8e05c000 task.ti: 8e05c000
[ 1.056830] PC is at serial_imx_probe+0x214/0x3f0
[ 1.063423] LR is at clk_core_get_rate+0x3c/0x60
[ 1.069941] pc : [<80355870>] lr : [<8049ffd4>] psr: 20000113
[ 1.069941] sp : 8e05de48 ip : 00000000 fp : 00000000
[ 1.085303] r10: 8e170880 r9 : fffffffa r8 : 00000119
[ 1.092431] r7 : 8e172a10 r6 : 8e172a00 r5 : 8e065a40 r4 : 8e0b4410
[ 1.100860] r3 : a08c0000 r2 : 00000001 r1 : 00000000 r0 : 016e3600
[ 1.109272] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 1.120290] Control: 10c5387d Table: 8000406a DAC: 00000015
[ 1.127970] Process swapper/0 (pid: 1, stack limit = 0x8e05c210)
[ 1.135955] Stack: (0x8e05de48 to 0x8e05e000)
[ 1.142254] de40: 8e34af00 8e174410 807bee20 8e172a10 8e172a10 fffffffe
[ 1.154289] de60: 808d6f90 fffffdfb 00000000 808a295c 00000007 80361398 8094d8c8 8e172a10
[ 1.166376] de80: 808d6f90 00000000 00000000 8035fc24 8e172a10 808d6f90 8e172a44 00000000
[ 1.178615] dea0: 00000000 8035fe28 00000000 808d6f90 8035fd9c 8035e2cc 8e05ea5c 8e166f34
[ 1.190981] dec0: 808d6f90 8e369e80 808d7f40 8035f360 807bf738 808d6fd4 808d6f90 808d6f90
[ 1.203423] dee0: 808b9860 8e36fb00 80884e28 80360454 00000000 808b9860 8e36fb00 80884e4c
[ 1.215952] df00: 808b9860 80009678 808bfb64 808a2938 00000000 801414ec 808bfc00 8e120600
[ 1.228641] df20: 00000000 808be4c0 80836f68 0000003d 8fb9c469 8004517c 00000000 807d58dc
[ 1.241478] df40: 00000006 00000006 8fb9c477 8078655c 808be4a8 000000a6 808fc000 000000a6
[ 1.254504] df60: 808fc000 808fc000 808ac13c 808a2954 808a295c 80864db8 00000006 00000006
[ 1.267666] df80: 808645a0 806171bc 00000000 806171bc 00000000 00000000 00000000 00000000
[ 1.280884] dfa0: 00000000 806171c4 00000000 8000f328 00000000 00000000 00000000 00000000
[ 1.294215] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.307627] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 8f6f7dd7 43f98bfb
[ 1.321075] [<80355870>] (serial_imx_probe) from [<80361398>] (platform_drv_probe+0x48/0xa4)
[ 1.334782] [<80361398>] (platform_drv_probe) from [<8035fc24>] (driver_probe_device+0x174/0x2a8)
[ 1.348932] [<8035fc24>] (driver_probe_device) from [<8035fe28>] (__driver_attach+0x8c/0x90)
[ 1.362645] [<8035fe28>] (__driver_attach) from [<8035e2cc>] (bus_for_each_dev+0x68/0x9c)
[ 1.376100] [<8035e2cc>] (bus_for_each_dev) from [<8035f360>] (bus_add_driver+0xf4/0x1e8)
[ 1.389560] [<8035f360>] (bus_add_driver) from [<80360454>] (driver_register+0x78/0xf4)
[ 1.402852] [<80360454>] (driver_register) from [<80884e4c>] (imx_serial_init+0x24/0x40)
[ 1.416239] [<80884e4c>] (imx_serial_init) from [<80009678>] (do_one_initcall+0x8c/0x1d0)
[ 1.429719] [<80009678>] (do_one_initcall) from [<80864db8>] (kernel_init_freeable+0x144/0x1d4)
[ 1.443733] [<80864db8>] (kernel_init_freeable) from [<806171c4>] (kernel_init+0x8/0xe8)
[ 1.457136] [<806171c4>] (kernel_init) from [<8000f328>] (ret_from_fork+0x14/0x2c)
[ 1.470008] Code: e5d43118 e3130002 0a000017 e5943008 (e593a090)
[ 1.478805] ---[ end trace fe16bd731d3da7b7 ]---
[ 1.486133] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.486133]
[ 1.502930] CPU0: stopping
[ 1.508069] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.1.39-2.7.2+gba2f75f #3
[ 1.521298] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 1.529454] [<8001572c>] (unwind_backtrace) from [<8001279c>] (show_stack+0x10/0x14)
[ 1.541902] [<8001279c>] (show_stack) from [<80618cb4>] (dump_stack+0x84/0x98)
[ 1.553814] [<80618cb4>] (dump_stack) from [<80014a8c>] (handle_IPI+0x14c/0x16c)
[ 1.565887] [<80014a8c>] (handle_IPI) from [<800093e4>] (gic_handle_irq+0x5c/0x60)
[ 1.578131] [<800093e4>] (gic_handle_irq) from [<80013240>] (__irq_svc+0x40/0x54)
[ 1.590282] Exception stack(0x808b3f48 to 0x808b3f90)
[ 1.597666] 3f40: 00000001 00000000 00000000 8001e520 808b2000 808b55a8
[ 1.610412] 3f60: 80620400 00000000 808b3f98 00000000 00000001 00000000 01000000 808b3f90
[ 1.623127] 3f80: 8000fd4c 8000fd50 60000013 ffffffff
[ 1.630460] [<80013240>] (__irq_svc) from [<8000fd50>] (arch_cpu_idle+0x38/0x3c)
[ 1.642403] [<8000fd50>] (arch_cpu_idle) from [<8005ee00>] (cpu_startup_entry+0x250/0x2bc)
[ 1.655321] [<8005ee00>] (cpu_startup_entry) from [<80864c68>] (start_kernel+0x3a4/0x3b0)
[ 1.668421] [<80864c68>] (start_kernel) from [<8000807c>] (0x8000807c)
[ 1.677483] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.677483]
