My Colibri VF50 module cannot boot properly after power failing. It stops booting with such information:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
I’ve already got this error two times after power failing.
Is this true that fs crashing after loosening power? How can I prevent fs crashing in such cases (ups is not possible to use)?
We had seen issues before in the lower layered UBI and it also involved U-Boot and/or Fastmap, but this seems unlikely to be the issue here.
The message mentions an UBIFS error, it seems that a node got corrupted. UBIFS should be safe against power failures so this should really not happen.
It could be related to a file system full/almost full corner case issue. It is really hard for a file system to operate when it is about to be full, especially if it is a compressing file system like UBIFS. I recommend to strip down the image a bit, and/or disable logging so that there is always some space left.
I see that you are using a custom kernel, what changes, if any, do you made to the kernel?
Note that you don’t have 128MB NAND available for the root file system: There is overhead for the bad block management (~2MB), the Boot Loader, Kernel and Device Tree (~10MB) plus UBI wear leveling/volume managment and UBIFS file system overhead. With the LXDE image the NAND is pretty much full…
Did you flash the latest image from scratch ? If it is not flashed from scratch ateast make sure to erase the nand chip before flashing the latest image as mentioned in the article here. We are doing a powercut stress test on Colibri VF50 with our prebuild Linux Image, the test is running since 10-15-2016, so far no issues observed.
