Verdin iMX8MP Q 4GB IT V1.1A / Dahlia carrier board Rev. 1.1 / Linux Tdx Version 6.0/kirkstone
We are building a YOCTO image with customized device tree and additional recipes. The build generates a packed file called ‘Verdin-iMX8MP_ctc-tdx-image-Tezi_6.4.0-devel-20231124090122+build.0.tar’ that I am trying to flash using a USB stick.
I unpack the file and copy all 10 extracted files to a subdir on the USB stick. I put the Verdin in recovery mode and load EasyInstaller 5.7.3 into RAM using the Toradex supplied EZI.
Our Linux image shows up in EasyInstaller and can be installed without error message. Finally I select reboot.
In the bootloader console I can see the bootloader is running however it cannot start our Linux image.
The error message from bootloader reads: ---[ end **Kernel panic - not syncing: No working init found.** Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance. ]---
image.json (1.9 KB) from YOCTO build
Bootloader_Console.txt (25.4 KB)
Bootloader_Environment.txt (4.5 KB)
Bootloader_mmcInfo.txt (866 Bytes)
