Kernel modules recompilation issue
I’ve just did a git pull of the kernel from branch toradex_5.4-2.3.x-imx, recompiled the kernel and then when compiling the modules I had this issue:
  CALL    scripts/atomic/check-atomics.sh
  CALL    scripts/checksyscalls.sh
make[1]: *** No rule to make target 'debian/canonical-certs.pem', needed by 'certs/x509_certificate_list'.  Stop.
make[1]: *** Waiting for unfinished jobs....
make: *** [Makefile:1734: certs] Error 2
make: *** Waiting for unfinished jobs....
  CHK     include/generated/compile.h
  CHK     kernel/kheaders_data.tar.xz
I searched for and found this to be a working solution:
Do you approve using this certificate?
Adrian
Hi @adrmateu !
I just built both kernel and modules from toradex_5.4-2.3.x-imx without any errors:
Could you please check if you did the environment variables setup and also make toradex_defconfig before compiling?
Yep, I confirm it works.
Hi @adrmateu !
Great that it works.
Thanks for the feedback!
