Hi all,
In VF61, kernel is getting cr̥ash randomly. Below are the logs which shows the crash issue.
[175329.355177] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[175329.363413] pgd = 80004000
[175329.366220] [00000004] *pgd=00000000
[175329.369931] Internal error: Oops: 17 [#1] ARM
[175329.374388] Modules linked in: virtio_rpmsg_bus vf610_rpmsg virtio virtio_ring flexcan can_dev libcomposite configfs
[175329.385179] CPU: 0 PID: 66 Comm: kworker/u2:2 Not tainted 4.4.88-2.7.4+ge0f2806 #3
[175329.392889] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[175329.399478] task: 8f68a140 ti: 8f75e000 task.ti: 8f75e000
[175329.405028] PC is at process_one_work+0x2c/0x3d8
[175329.409785] LR is at worker_thread+0x78/0x564
[175329.414280] pc : [<8003553c>] lr : [<80036560>] psr: 00010093
[175329.414280] sp : 8f75fee0 ip : 8f75ff20 fp : 8f75ff1c
[175329.426012] r10: 8f74a800 r9 : 8f402000 r8 : 8f402000
[175329.431365] r7 : 8f74a818 r6 : 00000000 r5 : 8f74a800 r4 : 8f40200c
[175329.438024] r3 : 00000004 r2 : 8f402010 r1 : 8f40200c r0 : 8f74a800
[175329.444692] Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[175329.452076] Control: 10c5387d Table: 8db60059 DAC: 00000051
[175329.457957] Process kworker/u2:2 (pid: 66, stack limit = 0x8f75e208)
[175329.464440] Stack: (0x8f75fee0 to 0x8f760000)
[175329.468937] fee0: ffffe000 8f402014 8f402000 00000088 8f402000 8f402000 ffffe000 8f402014
[175329.477289] ff00: 8f74a818 00000088 8f402000 8f74a800 8f75ff5c 8f75ff20 80036560 8003551c
[175329.485638] ff20: 807bcc28 8f402160 808bf040 808eb49b 00000000 00000000 8f7497c0 8f75e000
[175329.493986] ff40: 8f74a800 800364e8 00000000 00000000 8f75ffac 8f75ff60 8003b1c4 800364f4
[175329.502334] ff60: 00000000 00000000 8003b0bc 8f74a800 00000000 8f75ff74 8f75ff74 00000000
[175329.510683] ff80: 8f75ff80 8f75ff80 80040a14 8f7497c0 8003b0bc 00000000 00000000 00000000
[175329.519031] ffa0: 00000000 8f75ffb0 8000fa78 8003b0c8 00000000 00000000 00000000 00000000
[175329.527378] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[175329.535727] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[175329.544060] Backtrace:
[175329.546663] [<80035510>] (process_one_work) from [<80036560>] (worker_thread+0x78/0x564)
[175329.554913] r10:8f74a800 r9:8f402000 r8:00000088 r7:8f74a818 r6:8f402014 r5:ffffe000
[175329.562975] r4:8f402000
[175329.565660] [<800364e8>] (worker_thread) from [<8003b1c4>] (kthread+0x108/0x110)
[175329.573211] r10:00000000 r9:00000000 r8:800364e8 r7:8f74a800 r6:8f75e000 r5:8f7497c0
[175329.581269] r4:00000000
[175329.583957] [<8003b0bc>] (kthread) from [<8000fa78>] (ret_from_fork+0x14/0x3c)
[175329.591332] r8:00000000 r7:00000000 r6:00000000 r5:8003b0bc r4:8f7497c0
[175329.598247] Code: e2136004 e1a05000 13c360ff e598300c (e5962004)
[175329.604478] —[ end trace 644d96da60d7174f ]—
[175329.609241] ------------[ cut here ]------------
[175329.614016] WARNING: CPU: 0 PID: 66 at /home/sysadmin/dhawal/bh_bpl_gcm/yocto/build_6700d/tmp-vfxx-nlg-glibc/work-shared/colibri-vf/kernel-source/kernel/softirq.c:150 __local_bh_enable_ip+0x98/0xcc()
[175329.631939] Modules linked in: virtio_rpmsg_bus vf610_rpmsg virtio virtio_ring flexcan can_dev libcomposite configfs
[175329.642772] CPU: 0 PID: 66 Comm: kworker/u2:2 Tainted: G D 4.4.88-2.7.4+ge0f2806 #3
[175329.651719] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[175329.658301] Backtrace:
[175329.660909] [<800136a0>] (dump_backtrace) from [<800138b8>] (show_stack+0x18/0x1c)
[175329.668632] r7:80024e68 r6:00000096 r5:00000009 r4:00000000
[175329.674497] [<800138a0>] (show_stack) from [<802acac4>] (dump_stack+0x24/0x28)
[175329.681892] [<802acaa0>] (dump_stack) from [<80021e74>] (warn_slowpath_common+0x88/0xb4)
[175329.690154] [<80021dec>] (warn_slowpath_common) from [<80021f44>] (warn_slowpath_null+0x24/0x2c)
[175329.699094] r8:00000000 r7:8f75fcc8 r6:00000000 r5:808eb48e r4:00000200
[175329.706012] [<80021f20>] (warn_slowpath_null) from [<80024e68>] (__local_bh_enable_ip+0x98/0xcc)
[175329.714976] [<80024dd0>] (__local_bh_enable_ip) from [<800769e0>] (cgroup_exit+0x50/0x74)
[175329.723314] r5:0000000b r4:8f68a140
[175329.727053] [<80076990>] (cgroup_exit) from [<80022bcc>] (do_exit+0x250/0x904)
[175329.734446] [<8002297c>] (do_exit) from [<80013c28>] (die+0x36c/0x3cc)
[175329.741102] r7:00000001
[175329.743788] [<800138bc>] (die) from [<8001e89c>] (__do_kernel_fault.part.0+0x6c/0x1f0)
[175329.751865] r10:8f74a800 r9:8f402000 r8:00000004 r7:00000000 r6:00000017 r5:8f75fe90
[175329.759921] r4:00000004
[175329.762609] [<8001e830>] (__do_kernel_fault.part.0) from [<8001a610>] (do_bad_area+0x0/0x90)
[175329.771202] r7:00000017 r4:8f75fe90
[175329.774942] [<8001a268>] (do_page_fault) from [<80009290>] (do_DataAbort+0x44/0xc0)
[175329.782751] r10:8f74a800 r9:8f402000 r8:8f75fe90 r7:00000004 r6:8001a268 r5:00000017
[175329.790816] r4:808bb894
[175329.793491] [<8000924c>] (do_DataAbort) from [<800142e0>] (__dabt_svc+0x40/0x60)
[175329.801047] Exception stack(0x8f75fe90 to 0x8f75fed8)
[175329.806231] fe80: 8f74a800 8f40200c 8f402010 00000004
[175329.814581] fea0: 8f40200c 8f74a800 00000000 8f74a818 8f402000 8f402000 8f74a800 8f75ff1c
[175329.822926] fec0: 8f75ff20 8f75fee0 80036560 8003553c 00010093 ffffffff
[175329.829674] r8:8f402000 r7:8f75fec4 r6:ffffffff r5:00010093 r4:8003553c
[175329.836593] [<80035510>] (process_one_work) from [<80036560>] (worker_thread+0x78/0x564)
[175329.844837] r10:8f74a800 r9:8f402000 r8:00000088 r7:8f74a818 r6:8f402014 r5:ffffe000
[175329.852901] r4:8f402000
[175329.855582] [<800364e8>] (worker_thread) from [<8003b1c4>] (kthread+0x108/0x110)
[175329.863138] r10:00000000 r9:00000000 r8:800364e8 r7:8f74a800 r6:8f75e000 r5:8f7497c0
[175329.871195] r4:00000000
[175329.873875] [<8003b0bc>] (kthread) from [<8000fa78>] (ret_from_fork+0x14/0x3c)
[175329.881249] r8:00000000 r7:00000000 r6:00000000 r5:8003b0bc r4:8f7497c0
[175329.888153] —[ end trace 644d96da60d71750 ]—
[175329.893094] Unable to handle kernel paging request at virtual address fffffff0
[175329.900478] pgd = 80004000
[175329.903311] [fffffff0] *pgd=8fdf6861, *pte=00000000, *ppte=00000000
[175329.909757] Internal error: Oops: 37 [#2] ARM
[175329.914238] Modules linked in: virtio_rpmsg_bus vf610_rpmsg virtio virtio_ring flexcan can_dev libcomposite configfs
[175329.925071] CPU: 0 PID: 66 Comm: kworker/u2:2 Tainted: G D W 4.4.88-2.7.4+ge0f2806 #3
[175329.934017] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[175329.940606] task: 8f68a140 ti: 8f75e000 task.ti: 8f75e000
[175329.946147] PC is at kthread_data+0x10/0x18
[175329.950460] LR is at wq_worker_sleeping+0x14/0xc0
[175329.955297] pc : [<8003b53c>] lr : [<80036c14>] psr: 20010193
[175329.955297] sp : 8f75fc38 ip : 8f75fc48 fp : 8f75fc44
[175329.967028] r10: 807b8528 r9 : 8f68a38c r8 : 00000000
[175329.972381] r7 : 8f75fcc8 r6 : 00000000 r5 : 808bdd98 r4 : 00000000
[175329.979040] r3 : 00000000 r2 : 1eb7d748 r1 : 00000000 r0 : 8f68a140
[175329.985697] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[175329.993083] Control: 10c5387d Table: 8db60059 DAC: 00000051
[175329.998964] Process kworker/u2:2 (pid: 66, stack limit = 0x8f75e208)
[175330.005447] Stack: (0x8f75fc38 to 0x8f760000)
[175330.009934] fc20: 8f75fc5c 8f75fc48
[175330.018280] fc40: 80036c14 8003b538 8f68a140 808bdd98 8f75fcac 8f75fc60 80648894 80036c0c
[175330.026628] fc60: 8f75fc84 8f75fc70 8f75fc84 8f75fc78 8005607c 8005601c 8f75fcc4 80648b98
[175330.034977] fc80: 800228e8 ffffe000 8f75fae4 8f450000 8f75fcc8 00000000 8f68a308 807b8528
[175330.043325] fca0: 8f75fcc4 8f75fcb0 80648b98 80648650 8f68a140 8f75fae4 8f75fce4 8f75fcc8
[175330.051674] fcc0: 80022f38 80648b60 8f75fcc8 8f75fcc8 80021f7c 00000001 8f75fd6c 8f75fce8
[175330.060022] fce0: 80013c28 80022988 8f75e208 0000000b 8f75fd14 8003553d 00000008 00000000
[175330.068371] fd00: 00000000 60010193 6575fd24 36333132 20343030 30613165 30303035 63333120
[175330.076720] fd20: 66303633 35652066 30333839 28206330 36393565 34303032 80002029 8008b01c
[175330.085068] fd40: 80819dec 00000004 8f75fe90 00000017 00000000 00000004 8f402000 8f74a800
[175330.093417] fd60: 8f75fd84 8f75fd70 8001e89c 800138c8 8f75fe90 00000017 8f75fddc 8f75fd88
[175330.101765] fd80: 8001a610 8001e83c 808be250 808ebec0 800519b8 808c8b38 00000000 00000000
[175330.110114] fda0: 00000001 8f406000 90003100 8f68a140 8f75fdd4 808bb894 00000017 8001a268
[175330.118463] fdc0: 00000004 8f75fe90 8f402000 8f74a800 8f75fe8c 8f75fde0 80009290 8001a274
[175330.126811] fde0: 9000210c 90002100 8f75fe28 90003100 8f75fe24 8f75fe00 80009400 8004dc04
[175330.135160] fe00: 808bf840 808bf848 8f75fe54 8f75fe18 8f68a170 8f68a140 0000d430 00000000
[175330.143508] fe20: 8f75fe5c 8f75fe30 80043598 8004348c 0000d430 00000000 8f402000 808bdd98
[175330.151857] fe40: 808bdd98 8f68a140 808bdd98 8f68a170 8f75fe84 8f75fe60 80043c18 80043218
[175330.160205] fe60: ffffffff 00000000 8f75fe9c 8003553c 00010093 ffffffff 8f75fec4 8f402000
[175330.168554] fe80: 8f75ff1c 8f75fe90 800142e0 80009258 8f74a800 8f40200c 8f402010 00000004
[175330.176902] fea0: 8f40200c 8f74a800 00000000 8f74a818 8f402000 8f402000 8f74a800 8f75ff1c
[175330.185251] fec0: 8f75ff20 8f75fee0 80036560 8003553c 00010093 ffffffff 00000051 80035440
[175330.193599] fee0: ffffe000 8f402014 8f402000 00000088 8f402000 8f402000 ffffe000 8f402014
[175330.201948] ff00: 8f74a818 00000088 8f402000 8f74a800 8f75ff5c 8f75ff20 80036560 8003551c
[175330.210297] ff20: 807bcc28 8f402160 808bf040 808eb49b 00000000 00000000 8f7497c0 8f75e000
[175330.218645] ff40: 8f74a800 800364e8 00000000 00000000 8f75ffac 8f75ff60 8003b1c4 800364f4
[175330.226993] ff60: 00000000 00000000 8003b0bc 8f74a800 00000000 8f75ff74 8f75ff74 00000001
[175330.235342] ff80: 8f75ff80 8f75ff80 80040a14 8f7497c0 8003b0bc 00000000 00000000 00000000
[175330.243690] ffa0: 00000000 8f75ffb0 8000fa78 8003b0c8 00000000 00000000 00000000 00000000
[175330.252038] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[175330.260386] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[175330.268719] Backtrace:
[175330.271321] [<8003b52c>] (kthread_data) from [<80036c14>] (wq_worker_sleeping+0x14/0xc0)
[175330.279596] [<80036c00>] (wq_worker_sleeping) from [<80648894>] (__schedule+0x250/0x510)
[175330.287841] r5:808bdd98 r4:8f68a140
[175330.291582] [<80648644>] (__schedule) from [<80648b98>] (schedule+0x44/0xa4)
[175330.298757] r10:807b8528 r9:8f68a308 r8:00000000 r7:8f75fcc8 r6:8f450000 r5:8f75fae4
[175330.306814] r4:ffffe000
[175330.309497] [<80648b54>] (schedule) from [<80022f38>] (do_exit+0x5bc/0x904)
[175330.316591] r5:8f75fae4 r4:8f68a140
[175330.320335] [<8002297c>] (do_exit) from [<80013c28>] (die+0x36c/0x3cc)
[175330.326996] r7:00000001
[175330.329680] [<800138bc>] (die) from [<8001e89c>] (__do_kernel_fault.part.0+0x6c/0x1f0)
[175330.337758] r10:8f74a800 r9:8f402000 r8:00000004 r7:00000000 r6:00000017 r5:8f75fe90
[175330.345822] r4:00000004
[175330.348505] [<8001e830>] (__do_kernel_fault.part.0) from [<8001a610>] (do_bad_area+0x0/0x90)
[175330.357103] r7:00000017 r4:8f75fe90
[175330.360842] [<8001a268>] (do_page_fault) from [<80009290>] (do_DataAbort+0x44/0xc0)
[175330.368652] r10:8f74a800 r9:8f402000 r8:8f75fe90 r7:00000004 r6:8001a268 r5:00000017
[175330.376717] r4:808bb894
[175330.379393] [<8000924c>] (do_DataAbort) from [<800142e0>] (__dabt_svc+0x40/0x60)
[175330.386948] Exception stack(0x8f75fe90 to 0x8f75fed8)
[175330.392132] fe80: 8f74a800 8f40200c 8f402010 00000004
[175330.400482] fea0: 8f40200c 8f74a800 00000000 8f74a818 8f402000 8f402000 8f74a800 8f75ff1c
[175330.408828] fec0: 8f75ff20 8f75fee0 80036560 8003553c 00010093 ffffffff
[175330.415575] r8:8f402000 r7:8f75fec4 r6:ffffffff r5:00010093 r4:8003553c
[175330.422493] [<80035510>] (process_one_work) from [<80036560>] (worker_thread+0x78/0x564)
[175330.430738] r10:8f74a800 r9:8f402000 r8:00000088 r7:8f74a818 r6:8f402014 r5:ffffe000
[175330.438802] r4:8f402000
[175330.441483] [<800364e8>] (worker_thread) from [<8003b1c4>] (kthread+0x108/0x110)
[175330.449039] r10:00000000 r9:00000000 r8:800364e8 r7:8f74a800 r6:8f75e000 r5:8f7497c0
[175330.457096] r4:00000000
[175330.459777] [<8003b0bc>] (kthread) from [<8000fa78>] (ret_from_fork+0x14/0x3c)
[175330.467158] r8:00000000 r7:00000000 r6:00000000 r5:8003b0bc r4:8f7497c0
[175330.474073] Code: e1a0c00d e92dd800 e24cb004 e5903220 (e5130010)
[175330.480301] —[ end trace 644d96da60d71751 ]—
[175330.485041] Fixing recursive fault but reboot is needed!
[175330.490492] Unable to handle kernel paging request at virtual address fffffff0
[175330.497871] pgd = 80004000
[175330.500701] [fffffff0] *pgd=8fdf6861, *pte=00000000, *ppte=00000000
[175330.507148] Internal error: Oops: 37 [#3] ARM
Can some one let me know how can I get it fixed and make VF61 work smothly without crash
Thannks in advance,
Lad Dhawal Umesh
