Kernel crash on hdmi display with 1440x540 resolution
Hello!
I have hdmi display with 1440x540 resolution.
Whet i try to connect this display to Toradex T30 i have kernel crash.
[    0.000000] Linux version 3.1.10-V2.6b2+g34c5824 (linuxdev@linuxdev.toradex.int) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP PREEMPT Wed Mar 30 21:15:37 CEST 2016
[    0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Toradex Apalis T30
[    0.000000] Found fbmem: 00c00000@bf400000
[    0.000000] Tegra reserved memory:
[    0.000000] LP0:                     00000000 - 00000000
[    0.000000] Bootloader framebuffer:  bf400000 - bfffffff
[    0.000000] Bootloader framebuffer2: 00000000 - 00000000
[    0.000000] Framebuffer:             be700000 - beffffff
[    0.000000] 2nd Framebuffer:         bf000000 - bfffffff
[    0.000000] Carveout:                00000000 - 00000000
[    0.000000] Vpr:                     00000000 - 00000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] fuse_speedo_calib: ATE prog ver 4.0
[    0.000000] Tegra3: CPU Speedo ID 2, Soc Speedo ID 2
[    0.000000] Tegra Revision: A03 SKU: 0xb0 CPU Process: 2 Core Process: 0
[    0.000000] tegra: PLLP fixed rate: 408000000
[    0.000000] Lowering sbus maximum rate from 378000000 to 334000000
[    0.000000] Lowering vde maximum rate from 600000000 to 520000000
[    0.000000] Lowering mpe maximum rate from 600000000 to 520000000
[    0.000000] Lowering 2d maximum rate from 600000000 to 520000000
[    0.000000] Lowering epp maximum rate from 600000000 to 520000000
[    0.000000] Lowering 3d maximum rate from 600000000 to 520000000
[    0.000000] Lowering 3d2 maximum rate from 600000000 to 520000000
[    0.000000] Lowering se maximum rate from 625000000 to 520000000
[    0.000000] Lowering host1x maximum rate from 300000000 to 267000000
[    0.000000] Lowering cbus maximum rate from 700000000 to 520000000
[    0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[    0.000000] Lowering ndflash maximum rate from 240000000 to 200000000
[    0.000000] Lowering sbc1 maximum rate from 160000000 to 100000000
[    0.000000] Lowering sbc2 maximum rate from 160000000 to 100000000
[    0.000000] Lowering sbc3 maximum rate from 160000000 to 100000000
[    0.000000] Lowering sbc4 maximum rate from 160000000 to 100000000
[    0.000000] Lowering sbc5 maximum rate from 160000000 to 100000000
[    0.000000] Lowering sbc6 maximum rate from 160000000 to 100000000
[    0.000000] Lowering dsia maximum rate from 500000000 to 432500000
[    0.000000] Lowering dsib maximum rate from 500000000 to 432500000
[    0.000000] Lowering cpu_g maximum rate from 1700000000 to 1400000000
[    0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000
[    0.000000] tegra dvfs: VDD_CPU nominal 1125mV, scaling enabled
[    0.000000] tegra dvfs: VDD_CORE nominal 1300mV, scaling enabled
[    0.000000] L310 cache controller enabled
[    0.000000] l2x0: 8 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x7e080001, Cache size: 1048576 B
[    0.000000] PERCPU: Embedded 8 pages/cpu @c14f6000 s10336 r8192 d14240 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 253211
[    0.000000] Kernel command line: core_edp_mv=1300 usb_high_speed=1 ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait igb_mac= consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 vmalloc=128M mem=1012M@2048M fbmem=12M@3060M video=tegrafb0:640x480-16@60 fbcon=map:1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 998MB = 998MB total
[    0.000000] Memory: 999552k/999552k available, 36736k reserved, 235520K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xff000000 - 0xffe00000   (  14 MB)
[    0.000000]     vmalloc : 0xf0800000 - 0xf8000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08dae44   (9036 kB)
[    0.000000]       .init : 0xc08db000 - 0xc0931860   ( 347 kB)
[    0.000000]       .data : 0xc0932000 - 0xc09c3814   ( 583 kB)
[    0.000000]        .bss : 0xc09c3838 - 0xc0a3cdc8   ( 486 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:800
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.003078] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
[    0.090130] pid_max: default: 32768 minimum: 301
[    0.090502] Mount-cache hash table entries: 512
[    0.091734] Initializing cgroup subsys blkio
[    0.091878] CPU: Testing write buffer coherency: ok
[    0.091978] ftrace: allocating 24855 entries in 74 pages
[    0.124152] CPU1: Booted secondary processor
[    0.124998] CPU2: Booted secondary processor
[    0.125812] CPU3: Booted secondary processor
[    0.125947] Brought up 4 CPUs
[    0.125983] SMP: Total of 4 processors activated (4787.40 BogoMIPS).
[    0.127136] devtmpfs: initialized
[    0.132490] print_constraints: dummy:
[    0.132889] NET: Registered protocol family 16
[    0.134217] host1x bus init
[    0.134445] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[    0.408419] apalis_t30_edp_init: CPU regulator 6000 mA
[    0.408509] Selecting UARTA as the debug console
[    0.408552] The debug console clock name is uarta_dbg
[    0.408917] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[    0.958425] console [ttyS0] enabled
[    0.984813] Registering the device TPS62360
[    0.989583] Clear bootloader IO dpd settings
[    1.075187] tegra: invalid EMC DFS table: entry for max rate 800000 kHz is not found
[    1.195529] tegra_iovmm_register: added iovmm-smmu
[    1.212454] bio: create slab <bio-0> at 0
[    1.217397] i2c-core: driver [tps6591x] using legacy suspend method
[    1.223711] i2c-core: driver [tps6591x] using legacy resume method
[    1.230400] SCSI subsystem initialized
[    1.237168] usbcore: registered new interface driver usbfs
[    1.242821] usbcore: registered new interface driver hub
[    1.248278] usbcore: registered new device driver usb
[    1.253501] tegra-otg tegra-otg: otg transceiver registered
[    1.260884] stmpe 4-0041: stmpe811 detected, chip id: 0x811
[    1.267786] tps6591x 4-002d: VERNUM is 02
[    1.274195] print_constraints: tps6591x_VDD_1: 1350 mV normal standby
[    1.282466] print_constraints: tps6591x_VDD_2: 1050 mV normal standby
[    1.290434] print_constraints: tps6591x_VDDCTRL: 800 <--> 1300 mV at 1012 mV normal standby
[    1.299491] print_constraints: tps6591x_VIO: 1800 mV normal standby
[    1.307060] print_constraints: tps6591x_LDO_1: 1800 mV normal standby
[    1.313573] set_supply: tps6591x_LDO_1: supplied by tps6591x_VIO
[    1.320772] print_constraints: tps6591x_LDO_2: 1200 mV normal standby
[    1.327277] set_supply: tps6591x_LDO_2: supplied by tps6591x_VIO
[    1.333868] print_constraints: tps6591x_LDO_3: 1200 mV normal standby
[    1.341015] print_constraints: tps6591x_LDO_4: 1000 <--> 1400 mV at 1200 mV normal standby
[    1.349841] print_constraints: tps6591x_LDO_5: 2800 mV normal standby
[    1.356849] print_constraints: tps6591x_LDO_6: 1000 <--> 1100 mV at 1100 mV normal standby
[    1.365188] set_supply: tps6591x_LDO_6: supplied by tps6591x_VIO
[    1.372519] print_constraints: tps6591x_LDO_7: 1200 mV normal standby
[    1.379008] set_supply: tps6591x_LDO_7: supplied by tps6591x_VIO
[    1.386066] print_constraints: tps6591x_LDO_8: 1000 mV normal standby
[    1.392585] set_supply: tps6591x_LDO_8: supplied by tps6591x_VIO
[    1.400701] print_constraints: tps62360: 900 <--> 1400 mV at 1100 mV normal standby
[    1.408688] pps_core: LinuxPPS API ver. 1 registered
[    1.413696] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.422902] PTP clock support registered
[    1.427181] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    1.434223] Bluetooth: Core ver 2.16
[    1.437876] NET: Registered protocol family 31
[    1.442340] Bluetooth: HCI device and connection manager initialized
[    1.448738] Bluetooth: HCI socket layer initialized
[    1.453648] Bluetooth: L2CAP socket layer initialized
[    1.458757] Bluetooth: SCO socket layer initialized
[    1.464099] cfg80211: Calling CRDA to update world regulatory domain
[    1.472001] print_constraints: fixed_reg_en_hdmi: 1800 mV normal
[    1.478455] print_constraints: fixed_reg_v3_3: 3300 mV normal
[    1.484787] print_constraints: gpio_reg_sdmmc3_vdd_sel: 1800 <--> 3300 mV at 1800 mV normal standby
[    1.493905] set_supply: gpio_reg_sdmmc3_vdd_sel: supplied by fixed_reg_v3_3
[    1.501774] tegra: failed to map regulator to power detect cell pwrdet_sdmmc3(-19)
[    1.509492] tegra: failed regulators mapping - io power detection is left always on
[    1.517195] Switching to clocksource timer_us
[    1.522525] Switched to NOHz mode on CPU #0
[    1.524233] Switched to NOHz mode on CPU #1
[    1.525064] Switched to NOHz mode on CPU #2
[    1.525877] Switched to NOHz mode on CPU #3
[    1.554263] nvmap_page_pool_init: nvmap uc page pool size=31236 pages
[    1.593724] nvmap_page_pool_init: nvmap pool = uc, highmem=31236, pool_size=31236,totalram=249888, freeram=217767, totalhigh=58880, freehigh=27575
[    1.747937] nvmap_page_pool_init: nvmap wc page pool size=31236 pages
[    1.793967] nvmap_page_pool_init: nvmap pool = wc, highmem=27520, pool_size=31236,totalram=249888, freeram=186472, totalhigh=58880, freehigh=0
[    1.949261] nvmap_page_pool_init: nvmap iwb page pool size=31236 pages
[    2.042576] nvmap_page_pool_init: nvmap pool = iwb, highmem=0, pool_size=31236,totalram=249888, freeram=155162, totalhigh=58880, freehigh=0
[    2.215921] tegra-nvmap tegra-nvmap: created carveout iram (255KiB)
[    2.237176] NET: Registered protocol family 2
[    2.241848] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    2.249634] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    2.259596] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    2.268060] TCP: Hash tables configured (established 131072 bind 65536)
[    2.274713] TCP reno registered
[    2.277877] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    2.283875] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    2.290658] NET: Registered protocol family 1
[    2.295530] RPC: Registered named UNIX socket transport module.
[    2.301476] RPC: Registered udp transport module.
[    2.306224] RPC: Registered tcp transport module.
[    2.310947] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.320280] host1x host1x: initialized
[    2.324200] PMU: registered new PMU device of type 0
[    2.329708] Tegra auto-hotplug initialized: disabled
[    2.334734] cpu-tegra: init EDP limit: 1250 MHz
[    2.340023] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[    2.346619] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[    2.352863] tegra_pcie_enable_regulators: unable to get pexio regulator
[    2.359498] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[    2.567234] PCIE: port 0: link down, retrying
[    2.771913] PCIE: port 0: link down, retrying
[    2.976589] PCIE: port 0: link down, retrying
[    2.980949] PCIE: port 0: link down, ignoring
[    3.185636] PCIE: port 1: link down, retrying
[    3.390307] PCIE: port 1: link down, retrying
[    3.594989] PCIE: port 1: link down, retrying
[    3.599346] PCIE: port 1: link down, ignoring
[    3.603937] PCI: bus0: Fast back to back transfers disabled
[    3.621653] PCI: bus1: Fast back to back transfers disabled
[    3.627496] pci 0000:00:00.0: BAR 8: assigned [mem 0x10000000-0x100fffff]
[    3.634307] pci 0000:00:00.0: BAR 7: assigned [io  0x10000000-0x10000fff]
[    3.641101] pci 0000:01:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff]
[    3.647909] pci 0000:01:00.0: BAR 0: set to [mem 0x10000000-0x1001ffff] (PCI address [0x10000000-0x1001ffff])
[    3.657839] pci 0000:01:00.0: BAR 3: assigned [mem 0x10020000-0x10023fff]
[    3.664645] pci 0000:01:00.0: BAR 3: set to [mem 0x10020000-0x10023fff] (PCI address [0x10020000-0x10023fff])
[    3.674572] pci 0000:01:00.0: BAR 2: assigned [io  0x10000000-0x1000001f]
[    3.681365] pci 0000:01:00.0: BAR 2: set to [io  0x10000000-0x1000001f] (PCI address [0x10000000-0x1000001f])
[    3.691291] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[    3.696529] pci 0000:00:00.0:   bridge window [io  0x10000000-0x10000fff]
[    3.703330] pci 0000:00:00.0:   bridge window [mem 0x10000000-0x100fffff]
[    3.725919] highmem bounce pool size: 64 pages
[    3.731184] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.738188] fuse init (API version 7.17)
[    3.742409] msgmni has been set to 1492
[    3.747291] io scheduler noop registered (default)
[    3.753946] mpe mpe: initialized
[    3.759437] gr3d gr3d: initialized
[    3.765045] gr2d gr2d: initialized
[    3.768941] isp isp: initialized
[    3.772807] tegradc tegradc.0: probed
[    3.776590] tegradc tegradc.0: use cmd options for tegrafb0: 640x480-16@60
[    3.783502] tegradc tegradc.0: switching framebuffer to 640x480
[    3.789424] tegradc tegradc.0: Calculated sync href=0 vref=1
[    3.795094] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[    3.806803] tegradc tegradc.0: probed
[    3.823813] tegradc tegradc.1: probed
[    3.827747] tegradc tegradc.1: use default mode for tegrafb1: 640x480-16@60
[    3.834745] tegradc tegradc.1: switching framebuffer to 640x480
[    3.840669] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[    3.852975] tegradc tegradc.1: hdmi: can't set audio to 44100 at 23750000 pix_clock
[    3.860759] tegradc tegradc.1: switching framebuffer to 640x480
[    3.860770] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[    3.881225] Console: switching to colour frame buffer device 80x30
[    3.921362] tegradc tegradc.1: probed
[    4.052144]       Display is GTF capable
[    4.057599] Unable to handle kernel NULL pointer dereference at virtual address 00000008
[    4.068758] pgd = c0004000
[    4.073006] [00000008] *pgd=00000000
[    4.078118] Internal error: Oops: 5 [#1] PREEMPT SMP
[    4.084633] Modules linked in:
[    4.089281] CPU: 0    Not tainted  (3.1.10-V2.6b2+g34c5824 #1)
[    4.096765] PC is at fb_videomode_to_var+0x14/0x94
[    4.103234] LR is at tegra_fb_update_monspecs+0x17c/0x1c4
[    4.110296] pc : [<c029fd54>]    lr : [<c02dd8cc>]    psr: 68000013
[    4.110304] sp : ef88fc58  ip : ef88fc68  fp : ef88fc64
[    4.125159] r10: 00000038  r9 : 00000038  r8 : 00000002
[    4.132064] r7 : 00000000  r6 : ef88fd8c  r5 : e6a96c00  r4 : e6a96e68
[    4.140280] r3 : 00000002  r2 : 0000000c  r1 : 00000000  r0 : e6a96c3c
[    4.148528] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[    4.159263] Control: 10c5387d  Table: 8000404a  DAC: 00000015
[    4.166788]
[    4.166792] PC: 0xc029fcd4:
[    4.174443] fcd4  e3a03ffa e594106c e5946074 e0000093 e5943000 e0831001 e5943078 e0811003
[    4.186189] fcf4  e5943068 e0811003 e5943004 e0836006 e594307c e0863003 e5946070 e0836006
[    4.198012] fd14  e5943084 e3130001 11a060a6 e3130002 11a06086 ebff31f9 e1a01006 ebff31f7
[    4.209977] fd34  e5850004 e89da8f0 3b9aca00 e1a0c00d e92dd800 e24cb004 e52de004 e8bd4000
[    4.222014] fd54  e5913008 e5803000 e591300c e5803004 e5913008 e5803008 e591300c e580300c
[    4.234262] fd74  e3a03000 e5803010 e5803014 e5913010 e5803064 e5913014 e5803068 e5913018
[    4.246650] fd94  e580306c e591301c e5803070 e5913020 e5803074 e5913024 e5803078 e5913028
[    4.259153] fdb4  e580307c e591302c e5803080 e5913030 e3c338ff e3c33cff e5803084 e89da800
[    4.271765]
[    4.271768] LR: 0xc02dd84c:
[    4.280189] d84c  e12fff33 e3500000 1a00000f e5960020 e24b10cc e0800009 ebff08f1 e5941008
[    4.292776] d86c  e5960020 e2811f8b e0800009 ebff0bbd e3580000 03a07001 ea000003 e5941008
[    4.305421] d88c  e020089a e2811f8b ebff0bb6 e2888001 eaffffda e3570000 1a000005 e2851f8b
[    4.318220] d8ac  e24b00cc e50b70cc e50b70c8 ebffff7b e5850234 e5951234 e285003c ebff091c
[    4.331135] d8cc  e5943008 e24b502c e52530d8 ebf5f6ab e1a01005 e3a0000b ebfef1e2 ebf5f7ec
[    4.344024] d8ec  ebf5f6a6 e1a01005 e3a0000a ebfef1dd ebf5f7e7 e5940008 e280000c eb0d38f9
[    4.356910] d90c  e24bd028 e89daff0 e1a0c00d e92ddff0 e24cb004 e24dd03c e52de004 e8bd4000
[    4.369793] d92c  e50b1050 e1a06003 e50b0058 e1a05002 e5921000 e3a09000 e51b0050 e50b9040
[    4.382680]
[    4.382684] SP: 0xef88fbd8:
[    4.391233] fbd8  c0981540 c02cc454 ef88fc0c ef88fbf0 c02cc454 c02bda74 c029fd54 68000013
[    4.403828] fbf8  ffffffff ef88fc44 ef88fc64 ef88fc10 c000db18 c00082d8 e6a96c3c 00000000
[    4.416400] fc18  0000000c 00000002 e6a96e68 e6a96c00 ef88fd8c 00000000 00000002 00000038
[    4.429193] fc38  00000038 ef88fc64 ef88fc68 ef88fc58 c02dd8cc c029fd54 68000013 ffffffff
[    4.442113] fc58  ef88fd6c ef88fc68 c02dd8cc c029fd4c 00000000 c09c9b31 ef88fcac ef88fc80
[    4.455002] fc78  c029cf20 c0275878 34202020 c029e0f4 5d343431 c029dc5c f08c4044 00000018
[    4.467900] fc98  e6a15850 f08c40c7 00000000 00000000 000005a0 0000021c 00000000 00000000
[    4.480812] fcb8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.493712]
[    4.493715] IP: 0xef88fbe8:
[    4.502262] fbe8  c02cc454 c02bda74 c029fd54 68000013 ffffffff ef88fc44 ef88fc64 ef88fc10
[    4.514854] fc08  c000db18 c00082d8 e6a96c3c 00000000 0000000c 00000002 e6a96e68 e6a96c00
[    4.527446] fc28  ef88fd8c 00000000 00000002 00000038 00000038 ef88fc64 ef88fc68 ef88fc58
[    4.540262] fc48  c02dd8cc c029fd54 68000013 ffffffff ef88fd6c ef88fc68 c02dd8cc c029fd4c
[    4.553183] fc68  00000000 c09c9b31 ef88fcac ef88fc80 c029cf20 c0275878 34202020 c029e0f4
[    4.566071] fc88  5d343431 c029dc5c f08c4044 00000018 e6a15850 f08c40c7 00000000 00000000
[    4.578961] fca8  000005a0 0000021c 00000000 00000000 00000000 00000000 00000000 00000000
[    4.591848] fcc8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.604737]
[    4.604741] FP: 0xef88fbe4:
[    4.613291] fbe4  ef88fbf0 c02cc454 c02bda74 c029fd54 68000013 ffffffff ef88fc44 ef88fc64
[    4.625883] fc04  ef88fc10 c000db18 c00082d8 e6a96c3c 00000000 0000000c 00000002 e6a96e68
[    4.638477] fc24  e6a96c00 ef88fd8c 00000000 00000002 00000038 00000038 ef88fc64 ef88fc68
[    4.651287] fc44  ef88fc58 c02dd8cc c029fd54 68000013 ffffffff ef88fd6c ef88fc68 c02dd8cc
[    4.664183] fc64  c029fd4c 00000000 c09c9b31 ef88fcac ef88fc80 c029cf20 c0275878 34202020
[    4.677090] fc84  c029e0f4 5d343431 c029dc5c f08c4044 00000018 e6a15850 f08c40c7 00000000
[    4.689979] fca4  00000000 000005a0 0000021c 00000000 00000000 00000000 00000000 00000000
[    4.702863] fcc4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.715742]
[    4.715745] R0: 0xe6a96bbc:
[    4.724312] 6bbc  ffbfffff f5ffe95f fffb9dfe f7fffffb fecb99fb f43feeff ffbfffef deffff7f
[    4.736891] 6bdc  ffffbb7f 7f77ffdf fdfdcff6 f77f9ffd fdfffffd dfffffff bffbff1f ffffefff
[    4.749467] 6bfc  bef5ffef 00000001 00000001 00000000 00000000 00000000 00000000 e6a96c18
[    4.762247] 6c1c  e6a96c18 ef88da80 00000001 00000000 00000000 e6a96c30 e6a96c30 00000000
[    4.775163] 6c3c  00000280 000001e0 00000280 000003c0 00000000 00000000 00000010 00000000
[    4.788047] 6c5c  0000000b 00000005 00000000 00000005 00000006 00000000 00000000 00000005
[    4.800958] 6c7c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.813834] 6c9c  00000000 0000a479 00000050 00000010 00000011 00000003 00000040 00000004
[    4.826720]
[    4.826724] R4: 0xe6a96de8:
[    4.835298] 6de8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.847887] 6e08  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.860480] 6e28  00000000 e6a96e2c e6a96e2c 00000000 c0995ef8 c097f328 e6a95800 00000001
[    4.873269] 6e48  f2000000 01000000 c0a2cbdc 00000000 e6a95600 e6a96e68 00000000 00000000
[    4.886165] 6e68  e6a86078 c097f320 e6a96c00 00000001 c097f8d0 00000000 00000000 00000000
[    4.899047] 6e88  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.911956] 6ea8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.924860] 6ec8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.937764]
[    4.937768] R5: 0xe6a96b80:
[    4.946305] 6b80  ebff6ff9 fffffffa 7affff73 bffefff7 1ffffd7d ffffffff 6effff7f fbfdff7f
[    4.958903] 6ba0  fffbf3ff fffbfffd 9afdfedd bfdfffff ffbffdff ffbf7ffe ffee7fbf ffbfffff
[    4.971496] 6bc0  f5ffe95f fffb9dfe f7fffffb fecb99fb f43feeff ffbfffef deffff7f ffffbb7f
[    4.984322] 6be0  7f77ffdf fdfdcff6 f77f9ffd fdfffffd dfffffff bffbff1f ffffefff bef5ffef
[    4.997208] 6c00  00000001 00000001 00000000 00000000 00000000 00000000 e6a96c18 e6a96c18
[    5.010117] 6c20  ef88da80 00000001 00000000 00000000 e6a96c30 e6a96c30 00000000 00000280
[    5.023007] 6c40  000001e0 00000280 000003c0 00000000 00000000 00000010 00000000 0000000b
[    5.035895] 6c60  00000005 00000000 00000005 00000006 00000000 00000000 00000005 00000000
[    5.048807]
[    5.048811] R6: 0xef88fd0c:
[    5.057356] fd0c  00000051 00000008 00000018 0000003c 00000002 00000000 00000000 00000000
[    5.069932] fd2c  00000000 00000000 00000000 00000000 00000000 ef88fd84 e6a86000 e6a1b8e0
[    5.082522] fd4c  00000005 00000001 c07c9094 e6a86b04 c097f8d0 ef88fd84 ef88fd70 c02cf634
[    5.095341] fd6c  c02dd75c e6a86000 e6a1b8e0 ef88fe3c ef88fd88 c02cf8d4 c02cf5dc c00b5d30
[    5.108220] fd8c  00000271 00000118 0000009b 00000119 00000154 00000253 00000046 00000137
[    5.121109] fdac  e6a157e0 00494953 00000000 00000000 00000000 00000000 00000000 00000000
[    5.133986] fdcc  00000000 33333133 00000037 00000000 00000000 00000002 00004758 00000000
[    5.146865] fdec  000007da 00000033 000088b8 00009088 03750668 03b084e0 00000021 003d0000
[    5.159772] Process swapper (pid: 1, stack limit = 0xef88e2f0)
[    5.167889] Stack: (0xef88fc58 to 0xef890000)
[    5.174487] fc40:                                                       ef88fd6c ef88fc68
[    5.187006] fc60: c02dd8cc c029fd4c 00000000 c09c9b31 ef88fcac ef88fc80 c029cf20 c0275878
[    5.199471] fc80: 34202020 c029e0f4 5d343431 c029dc5c f08c4044 00000018 e6a15850 f08c40c7
[    5.212142] fca0: 00000000 00000000 000005a0 0000021c 00000000 00000000 00000000 00000000
[    5.224928] fcc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.237696] fce0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.250494] fd00: 00000000 00003f1b 00000050 00000051 00000008 00000018 0000003c 00000002
[    5.263294] fd20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.276090] fd40: ef88fd84 e6a86000 e6a1b8e0 00000005 00000001 c07c9094 e6a86b04 c097f8d0
[    5.288898] fd60: ef88fd84 ef88fd70 c02cf634 c02dd75c e6a86000 e6a1b8e0 ef88fe3c ef88fd88
[    5.301695] fd80: c02cf8d4 c02cf5dc c00b5d30 00000271 00000118 0000009b 00000119 00000154
[    5.314502] fda0: 00000253 00000046 00000137 e6a157e0 00494953 00000000 00000000 00000000
[    5.327368] fdc0: 00000000 00000000 00000000 00000000 33333133 00000037 00000000 00000000
[    5.340404] fde0: 00000002 00004758 00000000 000007da 00000033 000088b8 00009088 03750668
[    5.353501] fe00: 03b084e0 00000021 003d0000 00dc0040 00030001 0d1d0401 00000000 e6a86000
[    5.366615] fe20: 00000000 c097f328 c097f320 c066853c ef88fe9c ef88fe40 c02c6524 c02cf7a8
[    5.379714] fe40: c066853c e6a86000 c097f328 e6a8679e fe940000 e6a83a00 c0965708 c0963470
[    5.392812] fe60: 00000000 65740000 66617267 ef003162 c0995320 c097f320 c02c5cc8 c0a2e8b0
[    5.405927] fe80: ef933b64 c0995320 00000000 00000000 ef88feb4 ef88fea0 c02b84e0 c02c5cd4
[    5.419025] fea0: c097f328 c097f35c ef88fedc ef88feb8 c0314e70 c02b849c c097f328 c097f35c
[    5.432132] fec0: c0995320 ef933b64 00000000 00000000 ef88fefc ef88fee0 c031500c c0314db0
[    5.445241] fee0: 00000000 c0995320 c0314f94 ef933b64 ef88ff24 ef88ff00 c0313a8c c0314fa0
[    5.458345] ff00: ef938f20 ef947958 c026f584 c0995320 e6a82960 00000000 ef88ff34 ef88ff28
[    5.471461] ff20: c0314ab8 c0313a04 ef88ff64 ef88ff38 c03146e0 c0314a9c c078d570 ef88ff48
[    5.484578] ff40: c026f94c c0995320 c09c3840 c08f3c80 ef88e000 00000000 ef88ff84 ef88ff68
[    5.497677] ff60: c03156e8 c03145f8 c092e0fc c09c3840 c08f3c80 ef88e000 ef88ff94 ef88ff88
[    5.510794] ff80: c02b8548 c0315644 ef88ffa4 ef88ff98 c08f3ca0 c02b84f8 ef88ffe4 ef88ffa8
[    5.523905] ffa0: c0008754 c08f3c8c ef88ffc4 0000031f c09844c8 c00a14bc ef88ffe4 c092e0fc
[    5.537007] ffc0: c092e658 c000ec00 00000013 00000000 00000000 00000000 ef88fff4 ef88ffe8
[    5.550126] ffe0: c08db948 c00086b8 00000000 ef88fff8 c000ec00 c08db8bc 20042000 00c08820
[    5.563269] [<c029fd54>] (fb_videomode_to_var+0x14/0x94) from [<c02dd8cc>] (tegra_fb_update_monspecs+0x17c/0x1c4)
[    5.578521] [<c02dd8cc>] (tegra_fb_update_monspecs+0x17c/0x1c4) from [<c02cf634>] (tegra_dc_hdmi_detect_config+0x64/0xa8)
[    5.594453] [<c02cf634>] (tegra_dc_hdmi_detect_config+0x64/0xa8) from [<c02cf8d4>] (tegra_dc_hdmi_detect+0x138/0x154)
[    5.610042] [<c02cf8d4>] (tegra_dc_hdmi_detect+0x138/0x154) from [<c02c6524>] (tegra_dc_probe+0x85c/0x95c)
[    5.624659] [<c02c6524>] (tegra_dc_probe+0x85c/0x95c) from [<c02b84e0>] (nvhost_drv_probe+0x50/0x5c)
[    5.638778] [<c02b84e0>] (nvhost_drv_probe+0x50/0x5c) from [<c0314e70>] (driver_probe_device+0xcc/0x19c)
[    5.653221] [<c0314e70>] (driver_probe_device+0xcc/0x19c) from [<c031500c>] (__driver_attach+0x78/0x9c)
[    5.667577] [<c031500c>] (__driver_attach+0x78/0x9c) from [<c0313a8c>] (bus_for_each_dev+0x94/0xa4)
[    5.681605] [<c0313a8c>] (bus_for_each_dev+0x94/0xa4) from [<c0314ab8>] (driver_attach+0x28/0x30)
[    5.695431] [<c0314ab8>] (driver_attach+0x28/0x30) from [<c03146e0>] (bus_add_driver+0xf4/0x230)
[    5.709182] [<c03146e0>] (bus_add_driver+0xf4/0x230) from [<c03156e8>] (driver_register+0xb0/0x128)
[    5.723213] [<c03156e8>] (driver_register+0xb0/0x128) from [<c02b8548>] (nvhost_driver_register+0x5c/0x70)
[    5.737864] [<c02b8548>] (nvhost_driver_register+0x5c/0x70) from [<c08f3ca0>] (tegra_dc_module_init+0x20/0x28)
[    5.752868] [<c08f3ca0>] (tegra_dc_module_init+0x20/0x28) from [<c0008754>] (do_one_initcall+0xa8/0x164)
[    5.767332] [<c0008754>] (do_one_initcall+0xa8/0x164) from [<c08db948>] (kernel_init+0x98/0x130)
[    5.781093] [<c08db948>] (kernel_init+0x98/0x130) from [<c000ec00>] (kernel_thread_exit+0x0/0x8)
[    5.794829] Code: e92dd800 e24cb004 e52de004 e8bd4000 (e5913008)
[    5.804016] ---[ end trace 6fcb132ac310d004 ]---
[    5.810153] Kernel panic - not syncing: Attempted to kill init!
[    5.817607] [<c0014b10>] (unwind_backtrace+0x0/0xe8) from [<c062695c>] (dump_stack+0x20/0x24)
[    5.829094] [<c062695c>] (dump_stack+0x20/0x24) from [<c0626d80>] (panic+0x7c/0x198)
[    5.839789] [<c0626d80>] (panic+0x7c/0x198) from [<c005ee7c>] (do_exit+0xa4/0x6d4)
[    5.850321] [<c005ee7c>] (do_exit+0xa4/0x6d4) from [<c0011c30>] (die+0x204/0x2b0)
[    5.860758] [<c0011c30>] (die+0x204/0x2b0) from [<c06269c4>] (__do_kernel_fault.part.0+0x64/0x84)
[    5.872593] [<c06269c4>] (__do_kernel_fault.part.0+0x64/0x84) from [<c0015870>] (do_page_fault+0x214/0x22c)
[    5.885308] [<c0015870>] (do_page_fault+0x214/0x22c) from [<c0015968>] (do_translation_fault+0x2c/0xac)
[    5.897673] [<c0015968>] (do_translation_fault+0x2c/0xac) from [<c0008310>] (do_DataAbort+0x44/0xa8)
[    5.909767] [<c0008310>] (do_DataAbort+0x44/0xa8) from [<c000db18>] (__dabt_svc+0x38/0x60)
[    5.920983] Exception stack(0xef88fc10 to 0xef88fc58)
[    5.927502] fc00:                                     e6a96c3c 00000000 0000000c 00000002
[    5.938540] fc20: e6a96e68 e6a96c00 ef88fd8c 00000000 00000002 00000038 00000038 ef88fc64
[    5.949584] fc40: ef88fc68 ef88fc58 c02dd8cc c029fd54 68000013 ffffffff
[    5.957689] [<c000db18>] (__dabt_svc+0x38/0x60) from [<c029fd54>] (fb_videomode_to_var+0x14/0x94)
[    5.969496] [<c029fd54>] (fb_videomode_to_var+0x14/0x94) from [<c02dd8cc>] (tegra_fb_update_monspecs+0x17c/0x1c4)
[    5.982701] [<c02dd8cc>] (tegra_fb_update_monspecs+0x17c/0x1c4) from [<c02cf634>] (tegra_dc_hdmi_detect_config+0x64/0xa8)
[    5.996594] [<c02cf634>] (tegra_dc_hdmi_detect_config+0x64/0xa8) from [<c02cf8d4>] (tegra_dc_hdmi_detect+0x138/0x154)
[    6.010159] [<c02cf8d4>] (tegra_dc_hdmi_detect+0x138/0x154) from [<c02c6524>] (tegra_dc_probe+0x85c/0x95c)
[    6.022744] [<c02c6524>] (tegra_dc_probe+0x85c/0x95c) from [<c02b84e0>] (nvhost_drv_probe+0x50/0x5c)
[    6.034810] [<c02b84e0>] (nvhost_drv_probe+0x50/0x5c) from [<c0314e70>] (driver_probe_device+0xcc/0x19c)
[    6.047232] [<c0314e70>] (driver_probe_device+0xcc/0x19c) from [<c031500c>] (__driver_attach+0x78/0x9c)
[    6.059568] [<c031500c>] (__driver_attach+0x78/0x9c) from [<c0313a8c>] (bus_for_each_dev+0x94/0xa4)
[    6.071547] [<c0313a8c>] (bus_for_each_dev+0x94/0xa4) from [<c0314ab8>] (driver_attach+0x28/0x30)
[    6.083399] [<c0314ab8>] (driver_attach+0x28/0x30) from [<c03146e0>] (bus_add_driver+0xf4/0x230)
[    6.095203] [<c03146e0>] (bus_add_driver+0xf4/0x230) from [<c03156e8>] (driver_register+0xb0/0x128)
[    6.107275] [<c03156e8>] (driver_register+0xb0/0x128) from [<c02b8548>] (nvhost_driver_register+0x5c/0x70)
[    6.119994] [<c02b8548>] (nvhost_driver_register+0x5c/0x70) from [<c08f3ca0>] (tegra_dc_module_init+0x20/0x28)
[    6.133047] [<c08f3ca0>] (tegra_dc_module_init+0x20/0x28) from [<c0008754>] (do_one_initcall+0xa8/0x164)
[    6.145590] [<c0008754>] (do_one_initcall+0xa8/0x164) from [<c08db948>] (kernel_init+0x98/0x130)
[    6.157439] [<c08db948>] (kernel_init+0x98/0x130) from [<c000ec00>] (kernel_thread_exit+0x0/0x8)
[    6.169278] CPU1: stopping
[    6.173481] [<c0014b10>] (unwind_backtrace+0x0/0xe8) from [<c062695c>] (dump_stack+0x20/0x24)
[    6.184956] [<c062695c>] (dump_stack+0x20/0x24) from [<c00085bc>] (do_IPI+0xf0/0x1b0)
[    6.195723] [<c00085bc>] (do_IPI+0xf0/0x1b0) from [<c000db78>] (__irq_svc+0x38/0xd0)
[    6.206404] Exception stack(0xef8abcb0 to 0xef8abcf8)
[    6.212925] bca0:                                     00000001 0000000c 000002aa 00000004
[    6.223974] bcc0: ef8ba6a0 ef801ee0 00000002 00000003 ef801ef0 00000000 00000004 ef8abdcc
[    6.235002] bce0: 00000001 ef8abcf8 c00523b0 c026c580 20000113 ffffffff
[    6.243069] [<c000db78>] (__irq_svc+0x38/0xd0) from [<c026c580>] (__aeabi_uidiv+0x6c/0x9c)
[    6.254162] [<c026c580>] (__aeabi_uidiv+0x6c/0x9c) from [<c00523b0>] (find_busiest_group+0x24c/0x78c)
[    6.266213] [<c00523b0>] (find_busiest_group+0x24c/0x78c) from [<c00529d8>] (load_balance+0xe8/0x69c)
[    6.278264] [<c00529d8>] (load_balance+0xe8/0x69c) from [<c00554e8>] (rebalance_domains+0xf4/0x18c)
[    6.290147] [<c00554e8>] (rebalance_domains+0xf4/0x18c) from [<c0055664>] (run_rebalance_domains+0xe4/0x138)
[    6.302832] [<c0055664>] (run_rebalance_domains+0xe4/0x138) from [<c0061c78>] (__do_softirq+0xec/0x22c)
[    6.315112] [<c0061c78>] (__do_softirq+0xec/0x22c) from [<c0062264>] (irq_exit+0x60/0xb0)
[    6.326213] [<c0062264>] (irq_exit+0x60/0xb0) from [<c000858c>] (do_IPI+0xc0/0x1b0)
[    6.336779] [<c000858c>] (do_IPI+0xc0/0x1b0) from [<c000db78>] (__irq_svc+0x38/0xd0)
[    6.347435] Exception stack(0xef8abf70 to 0xef8abfb8)
[    6.353954] bf60:                                     ffffffed 00000001 ef8abf90 00000000
[    6.365042] bf80: ef8aa000 c0637194 10c0387d c09c3a90 8000406a 412fc099 00000000 ef8abfc4
[    6.376119] bfa0: ef8abfc8 ef8abfb8 c000f09c c000ec88 a0000013 ffffffff
[    6.384221] [<c000db78>] (__irq_svc+0x38/0xd0) from [<c000ec88>] (default_idle+0x28/0x2c)
[    6.395310] [<c000ec88>] (default_idle+0x28/0x2c) from [<c000f09c>] (cpu_idle+0xa8/0x104)
[    6.406391] [<c000f09c>] (cpu_idle+0xa8/0x104) from [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c)
[    6.418525] [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c) from [<806237f4>] (0x806237f4)
[    6.429872] CPU2: stopping
[    6.434013] [<c0014b10>] (unwind_backtrace+0x0/0xe8) from [<c062695c>] (dump_stack+0x20/0x24)
[    6.445383] [<c062695c>] (dump_stack+0x20/0x24) from [<c00085bc>] (do_IPI+0xf0/0x1b0)
[    6.456040] [<c00085bc>] (do_IPI+0xf0/0x1b0) from [<c000db78>] (__irq_svc+0x38/0xd0)
[    6.466605] Exception stack(0xef8d7f70 to 0xef8d7fb8)
[    6.473062] 7f60:                                     ffffffed 00000002 ef8d7f90 00000000
[    6.483975] 7f80: ef8d6000 c0637194 10c0387d c09c3a90 8000406a 412fc099 00000000 ef8d7fc4
[    6.494908] 7fa0: ef8d7fc8 ef8d7fb8 c000f09c c000ec88 a0000013 ffffffff
[    6.502957] [<c000db78>] (__irq_svc+0x38/0xd0) from [<c000ec88>] (default_idle+0x28/0x2c)
[    6.513937] [<c000ec88>] (default_idle+0x28/0x2c) from [<c000f09c>] (cpu_idle+0xa8/0x104)
[    6.524930] [<c000f09c>] (cpu_idle+0xa8/0x104) from [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c)
[    6.536990] [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c) from [<806237f4>] (0x806237f4)
[    6.548251] CPU3: stopping
[    6.552337] [<c0014b10>] (unwind_backtrace+0x0/0xe8) from [<c062695c>] (dump_stack+0x20/0x24)
[    6.563611] [<c062695c>] (dump_stack+0x20/0x24) from [<c00085bc>] (do_IPI+0xf0/0x1b0)
[    6.574252] [<c00085bc>] (do_IPI+0xf0/0x1b0) from [<c000db78>] (__irq_svc+0x38/0xd0)
[    6.584803] Exception stack(0xef8e5f70 to 0xef8e5fb8)
[    6.591263] 5f60:                                     ffffffed 00000003 ef8e5f90 00000000
[    6.602183] 5f80: ef8e4000 c0637194 10c0387d c09c3a90 8000406a 412fc099 00000000 ef8e5fc4
[    6.613126] 5fa0: ef8e5fc8 ef8e5fb8 c000f09c c000ec88 a0000113 ffffffff
[    6.621168] [<c000db78>] (__irq_svc+0x38/0xd0) from [<c000ec88>] (default_idle+0x28/0x2c)
[    6.632155] [<c000ec88>] (default_idle+0x28/0x2c) from [<c000f09c>] (cpu_idle+0xa8/0x104)
[    6.643157] [<c000f09c>] (cpu_idle+0xa8/0x104) from [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c)
[    6.655207] [<c0623ef8>] (secondary_start_kernel+0x13c/0x15c) from [<806237f4>] (0x806237f4)
The edid of this display is:
00FFFFFFFFFFFF004D29584700000000
33140104801D0D78070DC2A057479827
12484F000000010101010101010101010
10101010101A816A0DD501C2220513C
8204267110000018000000FE00333133
33370A202020202020202E18A0DD501C
2220513C8204277110000018000000FA
000100010001000100010001000A0005
How i can fix this?
Dear Toradex,
Do you have the same issue for other modules like Apalis iMX6 working on Ixora Carrier Board or it is just the issue of Tegra T30 board? Is it somehow related to the carrier board?
This patch will fix the kernel panic:
http://git1.toradex.com/cgit/linux-toradex.git/commit/?h=tegra-next&id=a208dd14ec53c9d041996d324286b078e5f806ea
However the 1440x540 resolution gives aspect ratio of 266.(6) which is unsupported by the driver.
You can try modifying drivers/video/tegra/dc/hdmi.c to either disable aspect ratio test in function tegra_dc_hdmi_valid_asp_ratio of add another aspect ratio to a table tegra_dc_hdmi_aspect_ratios and see if it works regardless.
I add apcept ratio to array. This fix kernel crash.
But in list of resolutin added strange resolution 256x160 and X server starting in this resolution at first time. But after reconnect HDMI the resolution setting been ok.
I patch file “drivers/video/tegra/dc/hdmi.c”
change line 1311
        if (mode->hsync_len > 1 && mode->vsync_len > 1 &&
                mode->lower_margin + mode->vsync_len + mode->upper_margin > 1 &&
                mode->xres >= 16 && mode->yres >= 16) {
to
                mode->xres >= 320 && mode->yres >= 240) {
Now all working ok.
Thanks for help.
