Kernel config request: CONFIG_LEDS_CLASS_MULTICOLOR
Many embedded devices these days use RGB (or other multiple-colour) LEDs and the Linux kernel does have the concept of binding individual LEDs together to associate them as a multicolour entity. Some multi-channel chips (e.g LP55xx) even support it directly in their driver code.
Would you consider enabling
CONFIG_LEDS_CLASS_MULTICOLOR as a Toradex kernel config change?
The code itself states it can be built as a module, but doing so out-of-band (e.g. via the TCB driver build step) does not work as there are functions in /include/linux/led-class-multicolor.h that change depending on whether multicolour support is enabled. Since it is not currently, the module cannot be built or side-loaded.
Greetings @bw908,
Sure thing, I’ll go ahead and put in the request to enable CONFIG_LEDS_CLASS_MULTICOLOR. As usual I’ll let you know once there’s an update regarding this request.
Awesome, thanks!
Alright, the team went ahead and enabled this config on the latest nightly builds as seen here:
torizon@apalis-imx8-06738453:~$ cat /etc/os-release
ID=torizon
NAME="TorizonCore"
VERSION="6.6.0-devel-20240316+build.532 (kirkstone)"
VERSION_ID=6.6.0-devel-20240316-build.532
PRETTY_NAME="TorizonCore 6.6.0-devel-20240316+build.532 (kirkstone)"
DISTRO_CODENAME="kirkstone"
BUILD_ID="532"
ANSI_COLOR="1;34"
VARIANT="Docker"
torizon@apalis-imx8-06738453:~$ zcat /proc/config.gz | grep CONFIG_LEDS_CLASS_MULTICOLOR
CONFIG_LEDS_CLASS_MULTICOLOR=m
