Kernel Compilation
I want to compile a specific device tree but I can’t find it, I take all configurations from Build U-Boot and Linux Kernel from Source Code, when I reach Kernel Compilation step, i.MX 6ULL Based Kernel (Colibri iMX6ULL) instead make DTC_FLAGS=“-@” imx6ull-colibri-eval-v3.dtb I want make DTC_FLAGS=“-@” imx6ull-colibri-aster.dtb.
Where can I find it or how can I add it?
Update: I found the imx6ull-colibri-aster.dtsi file, I activated the touch controller (status: okay-this was the customization I needed), and tried to compile the dtsi file using DTC and got the following error
dtc  -I dts -O dtb -i arch/arm/boot/dts/ -o test.dtb arch/arm/boot/dts/imx6ull-colibri-aster.dtsi
Error: arch/arm/boot/dts/imx6ull-colibri-aster.dtsi:10.1-2 syntax error
FATAL ERROR: Unable to parse input tree
Also how can I include the dtb file in the Linux image using bitbake ?
Colibri iMX6ULL, BSP 5
Thank you!
Hi @Dumitru
Could you provide the version of the hardware (including carrier board) and software of your module?
Regarding your question, you just need to type
Did you get any errors? What exactly is not working?
Best regards, Jaski
Hi @jaski.tx
Hardware version: Aster v1.1B
Error: make DTC_FLAGS="-@" imx6ull-colibri-aster.dtb make[1]: *** No rule to make target 'arch/arm/boot/dts/imx6ull-colibri-aster.dtb'. Stop. Makefile:1265: recipe for target 'imx6ull-colibri-aster.dtb' failed make: *** [imx6ull-colibri-aster.dtb] Error 2
Hi @Dumitru,
Upstream kernel sources don’t include imx6ull-colibri-aster.dts .
Hi @Dumitru
I did not know that you were compiling an upstream kernel. @Edward is right, Upstream kernel sources don’t include imx6ull-colibri-aster.dts yet. This will be integrated in future and patches are welcome.
I receive error:
CHK scripts/mod/devicetable-offsets.h
DTC arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb
./scripts/dtc/dtc: unrecognized option ‘–@’
at command: make DTC_FLAGS=“-@” imx6dl-colibri-eval-v3.dtb
make imx6dl-colibri-eval-v3.dtb
works fine, but is it ok?
commands:
git clone -b toradex_4.9-2.3.x-imx git://git.toradex.com/linux-toradex.git
make colibri_imx6_defconfig
make -j3 zImage LOADADDR=10008000 2>&1 | tee build.log
regards,
Klemen
Hi @medicalSpark ,
Please have a look at this section of the “Build U-Boot and Kernel from Source Code” Article.
Install the GNU Toolchain for Hard Float Calling Convention
For more information about the DTC flags, I recommend you have a look at this.
Kevin
I follow https://developer.toradex.com/knowledge-base/build-u-boot-and-linux-kernel-from-source-code#tab-17-imx-6
There is instruction:
To compile the kernel & device tree for BSP 2.8b2 or newer:
$ make -j$(nproc) zImage LOADADDR=10008000 2>&1 | tee build.log
$ make DTC_FLAGS="-@" <device-tree>.dtb
Hi @medicalSpark ,
In the end, seems like for BSP 2.8 DTC_FLAGS="-@" shouldn’t be used. We will review the documentation.
And for you question
Yes, it is ok.
