I setup the kernel toolchain as described. Did:
make colibri_imx7_defconfig to create .config file.
The build ran quite a while successfully, but ultimately failed:
LZO arch/arm/boot/compressed/piggy.lzo
CC arch/arm/boot/compressed/misc.o
/bin/sh: 1: lzop: Permission denied
receipe for target 'arch/arm/boot/compressed/piggy.lzo failed
CC arch/arm/boot/compressed/decompress.o
receipe for target 'arch/arm/boot/compressed/vmlinux failed
Any ideas?
Hi @bobpbbd104
Which git branch did you check out for the compilation? Have you done any Changes?
Did you install Build Tools for your host as explained here?
thanks for quick response. I checked out toradex_4.1-2.0.x-imx.
toolchain: https://releases.linaro.org/components/toolchain/binaries/5.2-2015.11-2/arm-linux-gnueabihf/gcc-linaro-5.2-2015.11-2-x86_64_arm-linux-gnueabihf.tar.xz
export ARCH=arm
export PATH=~/gcc-linaro/bin/:$PATH
export CROSS_COMPILE=arm-linux-gnueabihf-
Build seemed progress with 100’s of targets assembled or compiled, until the error.
