Hi i want to install the image generated with yocto using the toradex easy installer
on the following module: Col iMX8QXP 2GB WB IT V1.0 B
Now i am trying to load toradex easy installer: Colibri-iMX8X_ToradexEasyInstaller_5.4.0+build.4
After putting my module in the recovery mode i am loading the easy installer through the USB OTG interface using the command:
bash recovery-linux.sh
In the unzipped directory of the toradex easy installer
After this command the Tezi GUI shows up in the Display connected to the carrier board but then after a while the display freezes. In the Debug UART i get the following output:
Starting kernel ...
[ 0.130000] No BMan portals available!
[ 0.131195] No QMan portals available!
[ 0.360981] imx8qxp-lpcg-clk 37620000.clock-controller: failed to get clock parent names
[ 0.541349] mxsfb 5a180000.lcdif: Failed to create outputs
[ 0.857769] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 0.947387] debugfs: Directory '59040000.sai' with parent 'imx8qxp-sgtl5000' already present!
Running /etc/rc.local...
Toradex Easy Installer 5.4.0+build.4 ()
Starting udev
System time was Thu Apr 21 13:11:13 UTC 2022.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Thu Apr 21 13:11:13 UTC 2022.
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
# ip addr show
to display the Ethernet IP address(es) or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
/ # [ 23.365807] BUG: Bad rss-counter state mm:0000000046951093 type:MM_FILEPAGES val:541
[ 23.373613] BUG: Bad rss-counter state mm:0000000046951093 type:MM_ANONPAGES val:38
[ 23.381341] BUG: non-zero pgtables_bytes on freeing mm: 8192
[ 23.423982] Unable to handle kernel paging request at virtual address 0000000067e4b17d
[ 23.431952] Mem abort info:
[ 23.434810] ESR = 0x96000005
[ 23.437918] EC = 0x25: DABT (current EL), IL = 32 bits
[ 23.443253] SET = 0, FnV = 0
[ 23.446312] EA = 0, S1PTW = 0
[ 23.449456] Data abort info:
[ 23.452336] ISV = 0, ISS = 0x00000005
[ 23.456173] CM = 0, WnR = 0
[ 23.459147] user pgtable: 4k pages, 48-bit VAs, pgdp=00000000d67fe000
[ 23.465591] [0000000067e4b17d] pgd=00000000d5b60003, pud=0000000000000000
[ 23.472387] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 23.477957] Modules linked in: crct10dif_ce mwifiex_pcie mwifiex cfg80211 rfkill ad7879_i2c ad7879 mxc_jpeg_encdec
[ 23.488327] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.129-5.4.0+git.cb88cc157bfb #1
[ 23.496333] Hardware name: Toradex Colibri iMX8QXP on Colibri Evaluation Board V3 (DT)
[ 23.504256] pstate: 00000005 (nzcv daif -PAN -UAO)
[ 23.509060] pc : __memcpy+0x20/0x180
[ 23.512641] lr : fec_enet_rx_napi+0x5b4/0xa38
[ 23.516999] sp : ffff800010003d60
[ 23.520308] x29: ffff800010003d60 x28: ffff000058747840
[ 23.525624] x27: ffff000058747000 x26: 0000000000000048
[ 23.530941] x25: ffff000058747000 x24: 0000000000000000
[ 23.536257] x23: 0000000000000044 x22: ffff000055017300
[ 23.541574] x21: ffff00005860c000 x20: 0000000000000000
[ 23.546893] x19: ffff800012fc6a80 x18: 0000000000000000
[ 23.552207] x17: 0000000000000000 x16: 0000000000000000
[ 23.557524] x15: 0000000000000000 x14: 0000000000000000
[ 23.562841] x13: 0000000000000001 x12: 0000000000000000
[ 23.568158] x11: 0000000000000001 x10: 0000000000000040
[ 23.573475] x9 : ffff800011711768 x8 : 000000000000003f
[ 23.578791] x7 : ffff00005a03b048 x6 : ffff000055b4ea40
[ 23.584108] x5 : 0000000000000000 x4 : 0000000000000003
[ 23.589425] x3 : 000000000000003f x2 : 0000000000000041
[ 23.594742] x1 : 0000000067e4b17d x0 : ffff000055b4ea40
[ 23.600060] Call trace:
[ 23.602505] __memcpy+0x20/0x180
[ 23.605737] net_rx_action+0x114/0x340
[ 23.609489] __do_softirq+0x120/0x25c
[ 23.613157] irq_exit+0xb8/0xd8
[ 23.616300] __handle_domain_irq+0x64/0xb8
[ 23.620397] gic_handle_irq+0x5c/0x148
[ 23.624143] el1_irq+0xb8/0x180
[ 23.627291] arch_cpu_idle+0x10/0x18
[ 23.630868] do_idle+0x200/0x280
[ 23.634098] cpu_startup_entry+0x20/0x80
[ 23.638026] rest_init+0xd4/0xe0
[ 23.641260] arch_call_rest_init+0xc/0x14
[ 23.645271] start_kernel+0x408/0x43c
[ 23.648944] Code: f2400c84 540001c0 cb040042 36000064 (38401423)
[ 23.655044] ---[ end trace 5a066aa8f59b978a ]---
[ 23.659667] Kernel panic - not syncing: Fatal exception in interrupt
[ 23.666025] SMP: stopping secondary CPUs
[ 23.669953] Kernel Offset: disabled
[ 23.673444] CPU features: 0x0002,20002008
[ 23.677446] Memory Limit: none
[ 23.680506] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Is there a way to solve this problem?
