Dear Toradex,
Can you provide an export of the Ixora carrier boardAltium Designer project to the Eagle Schematics / PCB Project format?
Thank you
Chris Anderson
Dear Toradex,
Thank you
Chris Anderson
I submitted a ticket (2019123010000037) for this question via email, as well, but please post a response/link here.
Dear @chrisanderson1973,
thank you very much for using the Toradex community.
Could you please check if the files contained in this thread would work for you?
https://www.toradex.com/community/questions/1121/toradex-carrier-board-file-in-orcad-format.html
Unfortunately, we don’t use Eagle in our company therefore I cannot be sure if this works.
If they can be imported also in Eagle, I will export also the latest Ixora design data, so you will have the updated projects.
I hope this helps, looking forward to hearing back from you.
