When using the OTG port with an Apalis iMX8QM module VDD supplied to the micro USB port while the module is in reset even when the ID pin left floating (the board should be a peripheral).
I’ve removed JP2 which mean that the ID pin on the OTG port should control if the module acts as a host or a peripheral. I haven’t actually tried getting OTG to work (we’ve only used it as peripheral so far), but I noticed that LED3 lights up when holding the module in reset. A peripheral is prohibited from injecting voltage on VDD, so this seams like an issue. Also, the i.MX6 modules doesn’t do this.
I’m guessing the i.MX8 module drives (or pulls up?) USBO1_EN when in reset without respecting USBO1_ID. I’m not sure if this is cased by the actual SoC or if it’s the SoM. But a quick fix would be to add some logic in the middle of the USBO1_EN line that ands the signal with USB01_ID inverted?
