Hi all,
I have UART configured in my project but it seems like RX is influenced by TX.
I have IMX8QM running TorizonCore 5.7.2 on Ixora Carrier Board V1.2
I am using Pin 31 UART4_TXD and Pin 30 UART4_RXD on Ixora X27 Connector - which are Pin 138 and 140 in IMX8’s X1 Connector, respectively.
The UART is configured as below:
pin_mux.c:
void BOARD_InitPins(sc_ipc_t ipc)
sc_err_t err = SC_ERR_NONE;
err = sc_pad_set_all(ipc, BOARD_INITPINS_BB_UART2_TX_PIN_FUNCTION_ID, 1U, SC_PAD_CONFIG_NORMAL, SC_PAD_ISO_OFF, 0x0 ,SC_PAD_WAKEUP_OFF);
if (SC_ERR_NONE != err)
assert(false);
err = sc_pad_set_all(ipc, BOARD_INITPINS_BB_UART2_RX_PIN_FUNCTION_ID, 1U, SC_PAD_CONFIG_NORMAL, SC_PAD_ISO_OFF, 0x0 ,SC_PAD_WAKEUP_OFF);
assert(false);
pin_mux.h:
#define BOARD_INITPINS_BB_UART2_RX_PIN_FUNCTION_ID SC_P_LVDS0_I2C1_SDA
#define BOARD_INITPINS_BB_UART2_TX_PIN_FUNCTION_ID SC_P_LVDS0_I2C1_SCL
lpuart_confg.c:
#define TMC_LPUART DMA__LPUART2
#define TMC_LPUART_CLKSRC kCLOCK_DMA_Lpuart2
#define TMC_LPUART_CLK_FREQ CLOCK_GetIpFreq(kCLOCK_DMA_Lpuart2)
#define TMC_LPUART_TX_DMA_CHANNEL 17U
#define TMC_LPUART_RX_DMA_CHANNEL 16U
#define LPUART_DMA_BASEADDR DMA__EDMA0
lpuart_config.c:
void LPUART_EDMA_Config(sc_ipc_t ipc)
lpuart_config_t tmc_lpuartConfig;
lpuart_config_t test_lpuartConfig;
edma_config_t config;
uint32_t tmc_uart_freq;
/* Power on TMC LPUART for M4. */
if (sc_pm_set_resource_power_mode(ipc, SC_R_UART_2, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
assert(false);
if (sc_pm_set_resource_power_mode(ipc, SC_R_DMA_0_CH16, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
assert(false);
if (sc_pm_set_resource_power_mode(ipc, SC_R_DMA_0_CH17, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
assert(false);
/* Set tmc UART Clock frequency */
tmc_uart_freq = CLOCK_SetIpFreq(TMC_LPUART_CLKSRC, SC_133MHZ);
if (tmc_uart_freq == 0)
assert(tmc_uart_freq);
LPUART_GetDefaultConfig(&tmc_lpuartConfig);
tmc_lpuartConfig.baudRate_Bps = 256000 ;
tmc_lpuartConfig.enableTx = true;
tmc_lpuartConfig.enableRx = true;
LPUART_Init(TMC_LPUART, &tmc_lpuartConfig, TMC_LPUART_CLK_FREQ);
/* Init the EDMA module */
EDMA_GetDefaultConfig(&config);
EDMA_Init(LPUART_DMA_BASEADDR, &config);
EDMA_CreateHandle(&g_tmc_lpuartTxEdmaHandle, LPUART_DMA_BASEADDR, TMC_LPUART_TX_DMA_CHANNEL);
EDMA_CreateHandle(&g_tmc_lpuartRxEdmaHandle, LPUART_DMA_BASEADDR, TMC_LPUART_RX_DMA_CHANNEL);
LPUART_TransferCreateHandleEDMA(TMC_LPUART, &g_tmc_lpuartEdmaHandle, TMC_LPUART_UserCallback, NULL, &g_tmc_lpuartTxEdmaHandle,
&g_tmc_lpuartRxEdmaHandle);
Do you have any clue what would be the issue here?
Thank you in advance
Samir
