There are some issues in the scripts used in Toradex Benchmark Tests:
- When benchmarking a CPU with more than 1 cores, in dvfs_setup.sh, the min, max frequencies and scaling governor are set only for the 1st core.
- The latest version of the encode-flac test is 1.6.0 not 1.5.0.
Dear @sandu.gherbe
Welcome to the Toradex Community!
Thank you for the hints. Unfortunately this suite and scripts are not actively maintained by us anymore and we don’t plan to release anything new on that basis. If you want to apply the same settings for different CPUs, you can edit the script on yourself and copy the lines of CPU0. Additionally we will add a note to the article.
Best regards
Diego
