I’ve recently run into a problem using the debugger through VsCode. Running the “wait-debug-start-arm64” task in VsCode would result in an error stating that the ssh connection on the debug port was refused. I found that this was because the container was not running on the module.
The issue seems to be related to the following line of the “run-container-torizon-debug-arm”:
“LOCAL_REGISTRY=${config:host_ip} TAG=arm GPU=${config:torizon_gpu} docker-compose up -d testdebugging-debug”
If I ssh into the module and run this command, the container starts, but after a few seconds will exit with code 0.
If I instead start the container using the following docker run command, the container stays open, and I am able to use the debugger:
docker run -p 6502:6502 -p 6512:6512 -d 192.168.2.31:5002/test-debug:arm64 /usr/sbin/sshd -D
My understanding is that through that docker run command, I’m effectively doing the same things as what would happen using docker-compose up.
It might be worth noting that this behavior started after using the torizoncore-builder tool to update the device tree, but to me that seems unrelated.
Thanks,
Zack
Module: Verdin IMX8M Plus
Carrier: Verdin Dev Board V1.1E
TorizonCore 6.3.0+build.4 (kirkstone)
