Software summary
Bootloader: U-Boot
Kernel version: 6.6.74-7.2.0-devel-ge87d31337232 #1 SMP PREEMPT Wed Feb 26 11:01:24 UTC 2025
Kernel command line: root=PARTUUID=da1de54a-02 ro rootwait console=tty1 console=ttymxc2,115200
Distro name: NAME=“TDX Wayland with XWayland”
Distro version: VERSION_ID=7.2.0-devel-20250312062116-build.0
Distro variant: -
Hostname: verdin-imx8mp-15460290
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0063 V1.1B
Serial number: 15460290
Processor arch: aarch64
Hi there,
I am working on integrating the IW612-based Bluetooth module (MAYA-W27x: NXP IW612) with the Verdin i.MX8MP platform. While the Bluetooth functionality works correctly when RTS/CTS flow control is not used, I encounter issues when enabling RTS/CTS.
Specifically, when I connect the RTS and CTS pins between the host and the module, Bluetooth initialization fails with opcode timeouts and TX errors. Based on these symptoms, I suspect that the RTS/CTS handshake is not completing successfully.
root@verdin-imx8mp-15460290:~# modprobe btnxpuart
[ 42.127549] wlan: SCAN COMPLETED: scanned AP count=17
root@verdin-imx8mp-15460290:~# [ 42.439851] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 42.445247] Bluetooth: BNEP socket layer initialized
[ 43.266730] Bluetooth: hci0: FW already running.
[ 45.315028] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 47.330733] Bluetooth: hci0: Setting baudrate failed (-110)
root@verdin-imx8mp-15460290:~# [ 49.346732] Bluetooth: hci0: Setting wake-up method failed (-110)
[ 51.362750] Bluetooth: hci0: Setting Power Save mode failed (-110)
Interestingly, if I ground the CTS pin on the Bluetooth module and leave the RTS pin unconnected, the module initializes correctly and basic functionality appears to work. However, when I attempt to scan for nearby Bluetooth devices, the following errors occur:
root@verdin-imx8mp-15460290:~# hciconfig
hci0: Type: Primary Bus: UART
BD Address: 20:BA:36:56:BB:E0 ACL MTU: 1021:7 SCO MTU: 120:6
UP RUNNING PSCAN
RX bytes:902 acl:0 sco:0 events:65 errors:0
TX bytes:1610 acl:0 sco:0 commands:64 errors:0
root@verdin-imx8mp-15460290:~# bluetoothctl
hci0 new_settings: powered bondable ssp br/edr le secure-conn cis-central cis-p
Agent registered
[CHG] Controller 20:BA:36:56:BB:E0 Pairable: yes
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# pairable on
Changing pairable on succeeded
[bluetooth]# scan on
SetDiscoveryFilter success
hci0 type 7 discovering on
Discovery started
[CHG] Controller 20:BA:36:56:BB:E0 Discovering: yes
[bluetooth]# [ 139.054737] Bluetooth: hci0: Frame reassembly failed (-84)
[NEW] Device 44:A1:70:C1:74:43 44-A1-70-C1-74-43
[bluetooth]# [ 139.836671] Bluetooth: hci0: Frame reassembly failed (-84)
[ 139.842218] Bluetooth: hci0: Frame reassembly failed (-84)
[CHG] Device 4F:03:41:6A:A2:92 RSSI: 0xffffffaa (-86)
[bluetooth]# [ 139.985060] Bluetooth: hci0: Frame reassembly failed (-84)
[NEW] Device 36:D2:3A:FC:99:05 36-D2-3A-FC-99-05
[bluetooth]# [ 140.125421] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.167024] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.177003] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.187464] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.197413] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.202975] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.665359] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.729600] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.742113] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.747642] Bluetooth: hci0: Frame reassembly failed (-84)
[NEW] Device 2C:A7:EF:C5:1D:CE 2C-A7-EF-C5-1D-CE
[bluetooth]# [ 140.776055] Bluetooth: hci0: Frame reassembly failed (-84)
[ 140.833336] Bluetooth: hci0: Frame reassembly failed (-84)
Here’s my dts node;
&uart1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart1>;
assigned-clocks = <&clk IMX8MP_CLK_UART1>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
uart-has-rtscts;
bluetooth {
compatible = "nxp,88w8987-bt";
fw-init-baudrate = <115200>;
&iomuxc {
pinctrl_uart1: uart1grp {
fsl,pins =
<MX8MP_IOMUXC_SAI2_RXD0__UART1_DCE_RTS 0x1c4>, /* SODIMM 135 */
<MX8MP_IOMUXC_SAI2_TXFS__UART1_DCE_CTS 0x1c4>, /* SODIMM 133 */
<MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x1c4>, /* SODIMM 129 */
<MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x1c4>; /* SODIMM 131 */
My hardware connection are as follows:
| HOST SIDE | MODULE SIDE |
| VERDIN_UART1_TX | MODULE_UART_RX |
| VERDIN_UART1_RX | MODULE_UART_TX |
| VERDIN_UART1_CTS | MODULE_UART_RTS |
| VERDIN_UART1_RTS | MODULE_UART_CTS |
I have also tried reversing the RTS and CTS connections, but there was no change in behaviour.
Questions:
- What could be causing this failure when RTS/CTS is enabled?
- What configuration or hardware checks would you recommend to ensure proper RTS/CTS operation?
Thanks,
Pratham.
