Hi
I have a problem with the camera module OV5640 v1.1A connected to an Ixora v1.1A with an Apalis iMX6Q 1GB v1.1B. Additionally a capacitive touchscreen is connected to the Ixora.
The problem arises when I try to use the camera in a Qt Application (QML). I create a Camera via
import QtMultimedia 5.8
Camera {
deviceId: "video1"
And want to show the output on a VideoOutput:
VideoOutput {
source: camera
The camera seems to be found by Qt. The following yields the expected results:
print(QtMultimedia.availableCameras.length) // prints 1
print("deviceId: " + QtMultimedia.availableCameras[0].deviceId) // prints deviceId: /dev/video1
print("displayName: " + QtMultimedia.availableCameras[0].displayName) // prints displayName: video1
But I also get the following errors and the image is never displayed in the VideoOutput.
(qt_app:11892): GStreamer-CRITICAL **: gst_value_set_fraction: assertion 'denominator != 0' failed
Unable to query the parameter info: "Invalid argument"
CameraBin error: "Failed to allocate required memory."
CameraBin error: "Internal data stream error."
I built the image using BSP 2.8b5 based on the recipe “angstrom-qt5-x11-image” to which I added:
In local.conf:
IMAGE_INSTALL_append = " qtquickcontrols qtquickcontrols2 qtmultimedia qtdeclarative"
IMAGE_INSTALL_append = " opencv" -
In qtmultimedia_git.bb: Added “gstreamer” to PACKAGECONFIG (based on info from here)
PACKAGECONFIG ??= “${@bb.utils.contains(‘DISTRO_FEATURES’, ‘alsa’, ‘alsa’, ‘’, d)}
${@bb.utils.contains(‘DISTRO_FEATURES’, ‘pulseaudio’, ‘pulseaudio’, ‘’, d)}
gstreamer” -
In angstrom-qt5-x11-image.bb: Added “gstreamer1.0-plugins-bad-meta \” to GSTREAMER
GSTREAMER = "
gstreamer1.0
These steps (except the inclusion of opencv) seemed to be necessary to get rid of the following error when running my QML code.defaultServiceProvider::requestService(): no service found for - “org.qt-project.qt.camera”
Additional info:
The example given on here to run the camera with gstreamer does not work for me:
gst-launch-1.0 -v imxv4l2src device=/dev/video1 ! capsfilter caps="video/x-raw, width=1280, height=720, framerate=30/1" ! queue ! imxv4l2sink
WARNING: erroneous pipeline: no element "imxv4l2src"
I did run “setenv fdt_file imx6q-apalis-ixora-v1.1.dtb; saveenv” in U-Boot. The following command however is working and the camera feed is displayed on the connected display:
gst-launch-1.0 imxv4l2videosrc device=/dev/video1 ! autovideosink
So apparently the camera is recognized by the board and working.
v4l2-ctl shows the following information for /dev/video1:
v4l2-ctl -V --device=/dev/video1
[ 7240.458024] ov5640_set_virtual_channel: virtual channel=1
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'UYVY'
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
On the host computer, the application works fine using the internal webcam of my laptop.
What might be the problem here? Is this a Gstreamer issue? Or do I have to do some additional steps to set up the camera module?
Best
Patrik
