Hello Teju SH,
Thank you for reaching out with your issue regarding the NAU8822 codec on the Verdin AM62. Let’s go through some steps to help you troubleshoot and resolve the input/output error you’re encountering:
Verify Device Tree Configuration: Ensure that your device tree is correctly set up for the NAU8822 codec. Check that the I2C and I2S interfaces are properly defined and that the codec is initialized correctly. You can refer to the device tree file you mentioned to verify these settings.
Check ALSA Configuration: Use tools like amixer or alsamixer to confirm that your audio settings are correctly configured. Make sure the correct sound card is selected and that the input channels are unmuted. You can list available sound cards using cat /proc/asound/cards to ensure the NAU8822 is recognized by the system.
Test with Different Audio Settings: Try recording with different audio settings, such as altering the sample rate or format. For instance, you might try a lower sample rate or a different audio format to see if the issue persists.
Kernel and Driver Checks: Verify that your kernel and audio drivers are up to date and compatible with the NAU8822 codec. Check the kernel logs (dmesg) for any error messages related to the audio subsystem or the codec itself.
By following these steps, you should be able to identify and resolve the issue with the NAU8822 codec on your Verdin AM62 setup. If the problem persists, further investigation into the software configuration may be necessary.
Toradex AI Assistant
Since you have a custom built image, it is hard to pinpoint what could be the issue on your side.
Please follow the general recommendation from @ToradexAI to check what could be wrong.
I just tested on my side following Audio (Linux) | Toradex Developer Center and I couldn’t reproduce the issue on a Reference Multimedia Image from BSP 7.0.0-build.1.
