Hi, I am having trouble attempting to set a gpio pin as open-drain/pull-up with device tree overlays.
I am on apalis imx8 v1.1 with ixora carrier board v1.2. I am running windows as my host os. I am running a custom image based on the toradex 5.7.0+build.17
I am developing in python using the gpiod library
I can confirm the overlay is built during the building process of the custom image so it is included.
This is my current device tree overlay:
Here is my python code to set-up the gpio:
Since I have setup the gpio pin as open-drain with a pull-up resistor I expect the pin to be at ~0v when I set the pin to high and ~3.3v when I set the pin low. However, it shows 3.3v at high logic level and 0v at low logic levels which would be more expected of a push/pull setup.
Any advice would be appreciated. Thanks, Mike
