Issue in Debugging on Torizon ARMv7 Platform with VS Code
About System :
1)imx7 on iris carrier board
2)imx7 is connected device with vs code’s environment
3)followed instruction set from quickstart guide for imx7 , iris carrier board , windows (Supporting OS)
About Issue :
1)Local run with python is getting run.
2)When we choose Torizon ARMv7 and we debug , it shows a window(window’s “Show Errors” button shows blank result) (IMG attached below) and at TERMINAL , below message displayed :
failed to solve: failed to compute cache key: failed to calculate checksum of ref 72889994-4d08-41a7-8f8b-6aa18e0ea807::13klywe4mq7zotjswgagyirvz: “/usr/lib/aarch64-linux-gnu”: not found
Greetings @intersense.design,
I believe I know what the issue is. As seen from your error logs it fails on building your container specifically this line:
COPY --from=opengles /usr/lib/aarch64-linux-gnu /usr2/lib/aarch64-linux-gnu
This line targets the /usr/lib/aarch64-linux-gnu, directory but this directory is for arm64 devices which the imx7 is not. I see this line comes from our default templates here: https://github.com/toradex/vscode-torizon-templates/blob/dev/python3Pyside2QML/Dockerfile.debug#L123
Let me bring this up with our IDE team and see if we can get this cleared up.
Any updates on the issue?
Hi @intersense.design,
I believe this should be resolved now if you see the latest version of our templates: python3Pyside2QML: Fix the Dockerfiles · torizon/vscode-torizon-templates@95fb986 · GitHub
Are you still having this issue?
