I understand you’re still experiencing the Docker registry detection issue. Let me provide additional troubleshooting approaches based on the documentation.
Alternative Registry Configuration
Since the automatic detection is failing, you can configure the registry manually. The documentation shows how to set up a local registry as a pull-through cache(1):
Create a custom config.yml file:
version: 0.1
log:
fields:
service: registry
storage:
cache:
blobdescriptor: inmemory
filesystem:
rootdirectory: /var/lib/registry
proxy:
remoteurl: https://registry-1.docker.io
http:
addr: :5000
headers:
X-Content-Type-Options: [nosniff]
health:
storagedriver:
enabled: true
interval: 10s
threshold: 3
Manual Registry Setup with Docker Compose
Use this docker-compose file to run the registry with proper configuration(1):
version: "3"
services:
docker-registry:
container_name: docker-registry
image: registry.hub.docker.com/library/registry:2
ports:
- 5000:5000/tcp
volumes:
- ./config.yml:/etc/docker/registry/config.yml
- ${HOME}/registry:/var/lib/registry
restart: unless-stopped
Docker Daemon Configuration
Configure your Docker daemon to use the local registry. Create or modify /etc/docker/daemon.json in WSL(1):
"registry-mirrors" : ["<host-machine-ip>:5000"]
ARM Emulation Re-enablement
A common issue is that ARM emulation becomes disabled. The documentation states that “Enabling Arm emulation through this method is NOT persistent. After reboots, you have to run this command again to re-enable Arm emulation”(2).
Run this command to re-enable ARM emulation(2):
$ docker run --rm -it --privileged torizon/binfmt
WSL-Specific Solutions
For WSL environments, there are specific date/time synchronization issues that can affect Docker operations(3). If you’re experiencing certificate-related errors, run this in PowerShell with admin privileges(3):
$ wsl --shutdown
Registry Port Configuration
Based on community feedback, ensure your registry is properly accessible. The community documentation suggests checking these specific configurations(4):
- Registry binds to 0.0.0.0 (not 127.0.0.1)
- Windows firewall allows the registry port
- Docker’s daemon.json includes your registry as insecure
- Only one Docker Engine instance is active (inside WSL2)
Manual Task Execution
The extension provides specific scripts for dependency management(5). You can manually execute the registry setup task:
- Use the
run-docker-registrytask from the workspace tasks - Execute the
validate-deps-running.xshscript manually to see detailed error messages
Complete Environment Reset
If all else fails, try this complete reset approach:
- Stop all containers:
docker stop $(docker ps -aq) - Remove all containers:
docker rm $(docker ps -aq) - Restart WSL:
wsl --shutdownin PowerShell (admin) - Re-enable ARM emulation: Run the binfmt command above
- Start fresh registry: Use the docker-compose approach
- Reload VS Code: Developer: Reload Window
The persistent registry detection issue in WSL environments often requires this combination of ARM emulation re-enablement and proper registry configuration rather than relying solely on the extension’s automatic setup.
