I’m sorry to hear you’re having trouble building your Docker image. Let’s go through some steps to troubleshoot and hopefully resolve the issue:
Network Connectivity: Ensure your development environment has internet access, as ‘apt-get’ needs it to fetch packages from Debian repositories.
Verify Package Names: Double-check the package names in your Dockerfile. Make sure they are correct and available in the Debian repositories for the base image you are using.
Base Image Compatibility: Confirm that the base image (
wayland-base-vivante) is compatible with your TorizonCore version. You can verify this by checking the Toradex Docker Hub for the correct tags and versions. -
Update Package Lists: Ensure that ‘apt-get update’ completes successfully before running ‘apt-get install’. This step updates the package lists and is crucial for installing packages.
Check Dockerfile Syntax: Review your Dockerfile for any syntax errors that might affect the build process.
Repository Access: Sometimes, the issue might be due to temporary unavailability of Debian repositories. You might try building the image at a different time or check if there are any known issues with the repositories.
If these steps do not resolve the issue, consider simplifying the Dockerfile to isolate the problem. For instance, try building a minimal image with just the ‘apt-get update’ and ‘apt-get install’ commands to see if the error persists. This can help identify if the problem is with the specific packages or the overall setup.
I hope this helps you get your Docker image built successfully. If you have any more questions, feel free to ask.
