I’m getting the following error:
ERROR [2/2] RUN apt-get -y update && apt-get install -y --no-install-recommends libgstreamer1.0-0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly …
I’ve edited the dockerfile several times to try different base names, image arch and image tags, but I always get the same error.
The current arguments in the dockerfile are:
ARG BASE_NAME=wayland-base-vivante
ARG IMAGE_ARCH=linux/arm64/v8
ARG IMAGE_TAG=3
ARG DOCKER_REGISTRY=torizon
Same error.
Thanks for your help in advance.
I’m sorry to hear you’re having trouble building your Docker image. Let’s go through some steps to troubleshoot and hopefully resolve the issue:
Network Connectivity: Ensure your development environment has internet access, as ‘apt-get’ needs it to fetch packages from Debian repositories.
Verify Package Names: Double-check the package names in your Dockerfile. Make sure they are correct and available in the Debian repositories for the base image you are using.
Base Image Compatibility: Confirm that the base image (wayland-base-vivante) is compatible with your TorizonCore version. You can verify this by checking the Toradex Docker Hub for the correct tags and versions.
Update Package Lists: Ensure that ‘apt-get update’ completes successfully before running ‘apt-get install’. This step updates the package lists and is crucial for installing packages.
Check Dockerfile Syntax: Review your Dockerfile for any syntax errors that might affect the build process.
Repository Access: Sometimes, the issue might be due to temporary unavailability of Debian repositories. You might try building the image at a different time or check if there are any known issues with the repositories.
If these steps do not resolve the issue, consider simplifying the Dockerfile to isolate the problem. For instance, try building a minimal image with just the ‘apt-get update’ and ‘apt-get install’ commands to see if the error persists. This can help identify if the problem is with the specific packages or the overall setup.
I hope this helps you get your Docker image built successfully. If you have any more questions, feel free to ask.
What version of Torizon OS are you using on your Verdin i.MX8M Plus? If you’re on some version of 6.X, then you should be using the bookworm branch of that repository. I did a quick test and built the sample image on the bookworm branch and the image built successfully on my side.
If you still have issues with that, then you could share the full error message. You only shared a portion of it in your initial post, which makes it difficult to tell what kind of error you got.
Are you sure that is the full error message? It doesn’t really describe what went wrong exactly. It says there is an error, but it doesn’t say what the error was specifically.
As I said previously I built the sample container image from scratch, so I’m fairly confident it does build successfully.
If I were to take a guess at what your issue might be. I assume you’re building this on your development PC, correct? If that is the case did you make sure to enable arm emulation, so that arm/arm64 based-containers can be built on a non-arm machine?
That is indeed the full error message.
The issue was exactly the one you pointed out. After running the command that enables arm emulation I was able to build the image with no problem. I really appreciate your help on this!
Thank you!
