Issue building an out-of-tree module with torizonCore builder #2
Hello, I set up a new TCB yesterday. I downloaded the kernel source and device-trees source per the instructions.
Today, I was able to create my OS in Yocto. I moved my OS file Colibri-iMX7-eMMC_MP-OS-Image-Tezi_7.2.0-devel-20250312170710+build.0.tar into ./images in my TCB directory.
I ran torizoncore-builder images unpack ./images/Colibri-iMX7-eMMC_MP-OS-Image-Tezi_7.2.0-devel-20250312170710+build.0.tar
Then torizoncore-builder build, but it results in this error:
  File "/builder/torizoncore-builder", line 230, in <module>
    mainargs.func(mainargs)
  File "/builder/tcbuilder/cli/build.py", line 665, in do_build
    build(args.config_fname, args.storage_directory,
  File "/builder/tcbuilder/cli/build.py", line 628, in build
    fs_changes = handle_customization_section(
  File "/builder/tcbuilder/cli/build.py", line 197, in handle_customization_section
    handle_kernel_customization(props["kernel"], storage_dir=storage_dir)
  File "/builder/tcbuilder/cli/build.py", line 253, in handle_kernel_customization
    kernel_cli.kernel_build_module(
  File "/builder/tcbuilder/cli/kernel.py", line 81, in kernel_build_module
    assert linux_src, "panic: missing Linux kernel source!"
AssertionError: panic: missing Linux kernel source!
I suppose the issue has something to do with my custom Yocto output. Can you point me in the right direction?
The error message you’re encountering, “panic: missing Linux kernel source!”, suggests that the TorizonCore Builder tool is unable to locate the Linux kernel source required for building your out-of-tree module. Here are some steps to help you resolve this issue:
  1. Verify Kernel Source Path: Ensure that the path to the Linux kernel source is correctly specified in your build environment. The TorizonCore Builder tool needs this path to find the necessary files.
  2. Check Environment Variables: Confirm that the environment variable KERNEL_SRC or KDIR is correctly set in your Makefile. This variable should point to the directory where the Linux kernel source is located.
  3. Download Kernel Source: If you haven’t already, download the appropriate version of the Linux kernel source that matches your TorizonCore image. This can typically be obtained from the Toradex GitHub repository or other official sources.
  4. Review Configuration File: Check your tcbuild.yaml configuration file to ensure that the kernel: modules: source-dir parameter is correctly pointing to the directory containing your kernel module source code.
  5. Re-run Commands: After verifying the above steps, try re-running the torizoncore-builder build command to see if the issue persists.
By ensuring that the kernel source is correctly set up and accessible, you should be able to proceed with building your custom kernel module. If the problem continues, double-check the paths and environment settings to ensure there are no typos or misconfigurations.
Toradex AI Assistant
Device tree modification in Yocto for Colibri i.MX7 emmc.
Hi @kdubious
Well, the idea behind TorizonCore Builder (TCB) is that you either use it or use Yocto.
It was not designed to work together.
Can I ask why you want to use TCB? You could simply do everything on Yocto.
Also, is this a Torizon OS image? Are you using the torizon/default.xml manifest?
Initially, I thought I needed to patch the kernel so Yocto was my option. It looks like an FSL update may have removed that requirement for me.
The OSTree comparison (torizoncore-builder isolate) feature seems very useful, for example. It seemed to me from my reading that I could create a custom image in Yocto, then use it in TCB… but I suppose that’s not correct?
For right now, I am going to proceed with TCB.
Hi @kdubious
Well… that’s really hard to say… because it really depends on what type of modification you did in Yocto.
Do you still need any help with this topic?
I’m good at this point @allan.tx I’m proceeding with a default Torizon image for now, I may revisit Yocto again once we make some progress on the rest of the tooling.
